Is my engine about ready to say goodnight?
Hi everyone,
This morning the 2F in my 1987 developed some major issue that I fear may be the end of the line for the engine after 261,000 miles.
On the highway it would ping at times while under load, but it was not that bad....today was different. I was on the highway and the pinging/SLIGHT knocking suddenly became constant and loud even under a VERY light load. The engine almost sounds like a diesel while under load; even a light load. The other thing that became apparent is that it lost a large amount of power. When I pulled off the highway and came to a traffic light and allowed it to idle, the idle was very rough. The engine did not overheat, and the oil pressure remained good.
At home when it was parked at idle it also has a rough exhaust flow, almost like a constant small backfire.
Any ideas as to what is going on? What should I check at this point?
Thank you everyone,
Zack
PS: A hill near my home that I can usually fly up in 4th required me to downshift to 3rd and it almost needed 2nd. It was moving about 10 mph was the gas floored in 3rd.
Compression test
Look for bearing material in the oil
Look for coolant in the oil
Don't run it
When my 2F toasted the #5 rod bearing it sounded horrible but ran OK. It did loose some power.
Don't panic yet, it could just be in the valve train/head gasket, but as you say, it's life may be over.
Any recent work? Did your distributor slip? Could a carb/mixture issue give constant knock?
As Drew lists, but if the Compression is good, and the knock seems to be coming from the bottom end, then you prolly have to pull the pan to check rod bearings.
Sounds like it could be electrical, but hard to say. I'd check the plugs, ignitor, coil and distributor.
GL.
The initial check of the oil and spark plug wires (both ends) turned up nothing abnormal. The oil was seemingly free of any metal, at least from the dipstick and it had a perfect golden brown color (the oil has about 800 miles on it). All the plug wires were tight and the dizzy is tight in the engine.
I had to move it last night and it started and ran but terribly. At idle it shakes very bad. And I think the exhaust seems to be emitting terrible smells.
Zack
Rod Knock? Don't drive it till you confirm its not the bottom end, or you may end up with a hole in the block. Does it make the noise at idle (no load) if yes, you are probably looking a a rebuild or replace.
Dyno
Dyno
No, at idle it does not make any real noise at all......it just runs terrible.
Zack
check for a large-ish exhaust leak.....Hope that helps.
Get a compression and / or a leakdown test done. It sounds compression related to me if it won't run well at idle.
It may be something as simple as a burnt or sticking exhaust valve.
Have you checked the coolant yet? If not, then check it for the smell of fuel or oil, and obviously any discoloration due to oil mixing with the coolant.
It could be from any number of things. A compression test is the easiest thing to check. Take off the valve cover and look to see if your pushrods are still straight, rotate the engine by hand to see if all the rockers move...
I'm leaning towards head gasket, good luck.
Ok I will head to Sears to buy a compression tester. Now how do I use it? Should I do one cyl at a time? If so, do I leave all the plugs in except the cyl that I am testing? Do I pull all the plug wires or just the cyl that I am testing? Then once it is screwed into the cyl, how long should I crank the engine over? Will the pressure reading lock into he tester?
Sorry for all the questions, but I have never used one before.
Thanks,
Zack
