Intermittent electrical problems
"the whale's vagina", CA
Hi Guys,
Hoping someone has some suggestions as electrical is not always my cup of tea. Recently was driving my 96 80 series and my headlights (low beam) would just shut off all the sudden. The brights always worked. I had to drive for awhile with my brights on. The next day things went back to normal and everything worked fine on the long drive home. Next day I tried to unlock the doors and the door actuators did not have enough power to unlock, only the drivers would unlock. Basically acted like the battery was super low. Went out to get something out of the truck this morning and everything again worked as normal. Truck unlocked fine, etc, full power.
I have not done any investigation yet but wanted to see if anyone has had similar issues? Curious if there is something that goes bad on the electrical side of things I should look at? I am running the slee headlights harnesses with the toyota headlight switch. I am also running the sequoia upgraded alternator with an upgraded mega fuse to replace the stock fusible link.
First place I am going to look is a problem pulling power from the battery? but that does not make much sense as my stock headlights would not work but brights worked fine? defies logic in that if it were a current amount issue neither would work.
Has anyone seen these megafuses go bad slowly?
Thanks for the help.
Noah
Sounds like a ground issue.
I've been fighting a similar intermittent issue involving my tac which I can "fix" by turning on my lights bars or locking the torque converter via the lockup switch. Wish I could help more.
What he said. Sounds like a ground issue. You should spend time searching out and testing/cleaning ground connections. There are a bunch of em.
not sure. there are ground connections on the fender well next to the headlights. couple small wires bolted to the body with say a 6 mm bolt/10mm head. I believe the headlights are grounded there.
thx guys, yeah sounds like a ground issue to me too . . .
and this did not occur to your earlier, considering you have had a 40 for, like, how many years :flipoff2:
yup, 40s guys are always stumped by wiring :hillbilly: :lol:
(as opposed to seats, cupholders and oil viscosity for 80s guys :doh:)
