Hi All,
Getting tasks lined up on my build.
Thoughts on this?
Thoughts on this?
I'm fishing for ideas. Repair, replace, etc. I'm in western Washington.So are you in Washington or Canada? Was assuming you’re fishing for parts.
Good points. If I buy a used intake - seems consensus is to get the whole assembly flattened?Cast Aluminum is porous - oil/gas sinks into the pours, very hard to get a good weld, I'd look for a used intake $150 on up
I think this is a golden opportunity to add a header. I've heard that the two manifolds are matched to each other at the factory and fitting two strange manifolds together is hard. Pick a year intake that you like, match it to your new headers.Thoughts on this?
Hmm. I'm thinking header, desmog, and fuel injection.I think this is a golden opportunity to add a header. I've heard that the two manifolds are matched to each other at the factory and fitting two strange manifolds together is hard. Pick a year intake that you like, match it to your new headers.
While you're in there, you might think about a valve job. It used to be routine every 150k miles or so. Maybe install the Chevy valves. Maybe do a little port-matching with the head and the new intake and headers...Hmm. I'm thinking header, desmog, and fuel injection.
I agree. The engine has been fully rebuilt. Here are some pics on my build post.While you're in there, you might think about a valve job. It used to be routine every 150k miles or so. Maybe install the Chevy valves. Maybe do a little port-matching with the head and the new intake and headers...
