Installed Dobinson's 1.75 Inch Variable Rate Suspension Kit: C59 - 222V, C59 223V
This is good to know.
Do you know how tall your 80 is with the rack? I've got Flexi 3" right now, and barely fit in the garage. My goal is to fit in the garage with my 35s AND a rack so I'm looking at going down to the 222/223 combo.
Currenly on the flexi suspension when I put my camp gear in the rear it will squat about an inch or so. But unloaded it sits at 4"+ of lift in the rear which is pretty frustrating. When I load it full of camp gear and three people then its either level or even slightly squatting in the rear.
I don't really care if it squats, but I'd like it to bring me down 1.5-2" ideally. To make it easier for my wife and son to get in and also to add more clearance in the garage.
I am 82" roughly to the top of my rhino rack pioneer platform (with the RL mounts). my garage height is 82.01", this is how close it is. but it slips in just fine.
Just ordered a set of 222/223 with the adjustable MRA shocks and f/r panhards. My suspension sounds like it is going to fall apart, so this is long overdue. Currently stock weight, but plan is for a hidden winch and bolt on tire carrier.
@crikeymike thanks for all your help!
I see many of you are running 315s on OEM wheels with this setup, but how many of you also running the adjustable MRAs? Any rubbing or interference on the resivour up front with full stuff? From the photos I've found it looks like it will probably clear, but curious to hear first hand experience.
Trying to keep the OEM look and keep the wheels, but deep down I also want aftermarket wheels with more negative offset 😂
Any information is appreciated. Hopefully find time to install this kit after the holidays.
Another data point: I installed the 222 in front and 223 in rear of my 1997 LC with plan to add an ARB winch bumper and Comeup 9.5. No big bumper or drawers in the back, but probably Slee step sliders in the future.
Before:
LF 20.125 RF 19.875
LR 20.375 RR 21
(Full tank 3rd row removed)
After: LF 22.375 RF 22.625
LR 22.625 RR 23.25
Net lift initially:
LF 2.25 RF 2.5
LR 2 RR 2.25
Now I’ve got three Land Cruisers with a DS lean!! 😂😂😂
Since installing the lift, I added the ARB winch bumper, Comeup winch and Slee step sliders. With all those additions, I ended up with a 30mm spacer in the driver rear position and 20mm spacers up front to get a nice level stance. I was very happy with the ride and the look. Of course, I have subsequently pulled out the 1FZ and swapped in an aluminum LT 5.3L V8 and now the front is a little high. I'll start by removing the spacers in front and go from there. Probably end up with 10mm spacers in the front to get back to perfect.
222/223. Stock 80, bolt on tire carrier in the back. Before and after measurements taken with about 50-75lbs of stuff in the cargo area, and the tire carrier.
Before:
FL 19.5. FR 19.5
RL 19.75 RR 20.0
After
FL 22.25 FR 22.5
RL 21.5. RR 22.5
Rear left (driver side) is sagging an inch, which is common from what I've read.
@crikeymike and everyone else.... is adding a 1" spring spacer the best solution to this problem?
Very happy with this setup and glad i had this thread for some references. sitting at 22" center hub to fender on all four with all the gear. and still fit in the garage!
I went with 222V / 223V combo with the adjustable poly radius arm bushings set at 2.5 deg, truck drives great.
Who makes that rear bumper?
Before:
FL 19.5. FR 19.5
RL 19.75 RR 20.0
After
FL 22.25 FR 22.5
RL 21.5. RR 22.5
No, that's not normal. The rear coil marked R or Right is taller by 10mm and here in the USA that quite often has to be put on the Left side. Check which way they were installed.
I always tell everyone to put the new taller coil where the old taller coil was, so that they get in the correct position.
Before:
FL 19.5. FR 19.5
RL 19.75 RR 20.0
After
FL 22.25 FR 22.5
RL 21.5. RR 22.5
Mine was same. Added spacer. Maybe drive it for a day or two to see if it settles and confirm spacer height. ..And give yer back a break before getting in there again!
Thanks, I'll have a spacer available when I swap the coils..just in case that doesn't solve the problem. It's been over a week now so hopefully will get to it next weekend.
Great. And what @crikeymike said as a general rule, always put taller spring on drivers (left) side.
Small update after swapping rear R and L springs.
L side (driver) is now 21.75 and R side (passenger) is the same, at 22.5. This is an improvement, I should have compared spring height with OEM springs and installed accordingly.
I recently went on a trip and was able to take measurements fully loaded. Front height didn't change much at all. As a recap, I have a 12.5k hidden winch, rear bolt on tire carrier, no 3rd row, and ordered wkor sliders which will hopefully arrive before the next trip in June.
Not sure how heavy it was, but it was packed to the brim.
L side measured 20.75 (1 inch sag), and the R side measured at 22.0 ( 0.5 inch sag). I have a 15mm spacer that I'll pop in under the L side and I should be good. Got my new perry parts bumpstops, installed the rear so far, so it will be a good opportunity to flex and trim while the springs are out.
A few not so great photos I took. Appreciate everyone's input.
You can get on a CAT scale for cheap at Love's gas station. Get on after you get gas when you are empty or set as daily driving setup. Then weigh again with your max go out camping weight.
It's worth it. Helps with suspension tuning as well.
Hey @crikeymike . So you are saying that the Dobinson springs are still labeled for the Australian market so the right side needs to go on the left, and left on the right? I have the C59-223 in the rear and C59-222 in front also have about .5 inch difference from left to right
I currently have Left side on Left and Right side on Right.
Rear Left = 22.75
Rear Right = 23.25
Front Left = 22.5
Front Right = 23
Thanks in advance,
Jack
  • Like
Reactions: JSX
Rear Left = 22.75
Rear Right = 23.25
Front Left = 22.5
Front Right = 23
Thanks in advance,
Jack
You mark the stock springs left and right, then put the new taller coils onto the side that had the taller coil. Then there is no confusion.
You'll probably need to swap your rears if you didn't do it that way.
Thanks for this info. I just got off the phone with Dobinson USA and they said there springs are marked for the Australian market which would lead me to believe I have them all in the opposite way… I pulled out the rears and for the life of me I couldn’t tell a difference in height I mean super super close. I switched them around anyways and I think it was worse. However I just jumped on the back of the truck to settle the springs so I probably should have drove around on it but it looked way taller when I measured passenger side it was at 33.75.
This would lead me to believe that they in fact WERE labeled correctly and I just have a .5 inch lean which isn’t that bad and kinda hardly noticeable but I like to have my stuff dialed in. Anyways. I’m thoroughly confused. 🤔 appreciate your response.
Threw out my dang back yesterday so I don’t think switching them around again is in my near future! 🤣
-Jack
I went down the same road a couple years ago. Switched the backs, switched the fronts, switched and switched, and in the end ended up putting spacers on one side to get it level.
It’s definitely confusing if they are marked for the Australian market (per Dobinson USA) I would think they would be in backwards if you put the LEFT SIDE on the actual left side and RIGHT SIDE on the right side, seeing how the right side is heavier in the Australian vehicles due to it being the driver side and also gas tank side.
I guess sure fire way is to compare spring heights BEFORE installing. I thought I did that. Although my rears are so close in size I couldn’t tell a difference when I recently pulled them.
