I have 2020 and I get the 1st to 2nd gear clunk or not so smooth gear change when rolling real slow and then stepping on the gas but not smashing it. The jerky clunk is rare but it’s not something I want to happen again. Would the TSB fix this?
I reset the learning values of the engine a couple weeks back and noticed a decent change. The worst offenses in 1-2 clunk were eliminated. We drove with a bit more alacrity for the first tens of miles after the reset. The pedal in normal mode feels like it used to in ETC PWR mode. Even my wife noticed the smoother shifting and acceleration.Unclear. Toyota claims to have fixed the issue from the TSB for models beyond 2017. I haven't heard of anyone being able to get their transmission computer re-flashed since the firmware is supposedly up-to-date.
I've ordered a bi-directional diagnostic scanner that can do the same basic functionality as a Techstream. It can reset the engine/throttle learning, as well as the transmission memory. Will have some results on that progress soon.
Just add a pedal commander and you will be all set.I reset the learning values of the engine a couple weeks back and noticed a decent change. The worst offenses in 1-2 clunk were eliminated. We drove with a bit more alacrity for the first tens of miles after the reset. The pedal in normal mode feels like it used to in ETC PWR mode. Even my wife noticed the smoother shifting and acceleration.
I just did the transmission memory reset and the relearning driving patterns. In a test around the neighborhood, the hopeless transmission confusion is gone. It still shifts into first and there’s some flaring as throttle is applied. But it’s better. I wouldn’t say I love it by any stretch, and still is probably one of the less cooperative transmissions I’ve ever driven at low speed. But, it has moved out from the “tearing my hair out” zone. I hope it stays agreeable.
Hell yeah now get you a PC27 pedal commander to unleash the beast within!I also paid to have it done out of warranty so they charged .75/hr to do it which is what the TSB says on it...
Vast improvement and well worth it
you have solved the problem yet?I have 2020 and I get the 1st to 2nd gear clunk or not so smooth gear change when rolling real slow and then stepping on the gas but not smashing it. The jerky clunk is rare but it’s not something I want to happen again. Would the TSB fix this?
It hasn’t happened since then.you have solved the problem yet?
does it go away on its own?It hasn’t happened since then.
No idea, but I do the believe the transmission has a learning feature like many cars. I will try and replicate it when the roads are dry. I just detailed it the other day.does it go away on its own?
The transmission programming to downshift from 2 - 1 at 10mph never changes.No idea, but I do the believe the transmission has a learning feature like many cars. I will try and replicate it when the roads are dry. I just detailed it the other day.![]()
Does this help with the 1-2 shifts? Rolling stops are irritating.Hell yeah now get you a PC27 pedal commander to unleash the beast within!
Are you also having the same problem?Does this help with the 1-2 shifts? Rolling stops are irritating.
