Hydroboost
Houston
96-97 Lexus LX450 Hydro-Boost Conversion
My brake booster went out and am looking at a Hydroboost setup. Any idea on the difference between a 1994 and a 1996? Still waiting on the company reply as to the whether or not the OEM master cylinder can be used...
What's the advantage? I have to imagine new OEM Toyota parts are going to cost more than that. Looks like the 100 setup is electric, but I have to admit I'm not familiar.
Its electrohydraulic
The more I read about the less interested in it I become. Not an inexpensive piece of equipment and not known for being trouble free.
The main improvement you can get from going hydroboost is a larger MC. It’s my opinion that the stock MC could have had a larger bore.
I did hydro boost on the last crawler I built and with a ford 4 piston d60 up front and a disc converted 14ff in the rear, it stopped like nothing I’ve ever owned.
Unreliable? Says who? You can pick up a booster and MC off a GM truck at picknpull and put your own system together if you have the ability to make the necessary adapters.
What’s the name of the comapany you looked into.
The smallish bore of the LC MC allows for excellent modulation of the brakes. I do wonder if replacement of the vacuum booster with hydraboost would tighten up the pedal travel at all.
I had installed a hydaboost setup on my Jeep years back. Stock D44 brakes and factory MC. It had enough braking power to put you through the windshield, even on 35's. The 80's brake rotors are larger in diameter (12.26" vs 11.89"), and the calipers are of a superior design (single piston vs four piston) so the effect should be much more dramatic.
If you look at the posts I'm responding to you'll see that I'm talking specifically about the hydro-electric booster used in the 100-series Land Cruiser.
I'm a big fan of GM style hydroboost.
Non of you guys are concerned about stock tired PS pump ..?
I did that ( hydroboost ) on my 60 and had to replace my pump ( which was old and tired ) in order to make it work properly ..
Its not constantly working the pump though - it would generate pressure in an accumulator and then upon using the brakes, require a bit of fluid and pressure to recharge. So not really a big deal... if i understand these systems anyway
That’s why I thought of the 100 series: self contained, no drain on the P S pump?
its a gm/mopar booster and it uses a gm master cylinder. Your LC cylinder doesn't bolt up.
I like that idea too. My 4runner had that system and it stopped well. But @richardlillard1 seems to think its a horrible system because of some anecdote
It's a nice system, if you don't mind the failure mode.
