Well if you're dead and your vehicle is still intact it would probably be much easier.....because someone else would be changing your tire...see...there's always a Penglosian way to look at things. I will say on a serious note that neither hydroboost or vacuum boost are great if the engine dies. Used to drive an armored truck with hydroboost, if the engine dies you're essentially piloting a classic truck with manual brakes and steering. You get a couple pumps more than the vacuum boost but you shouldn't need it if you panic stop anyway.Not if youre dead
so the adapter is where the cost comes from. I just thought they were trying to make an obscene profit off of a ridiculously inexpensive setup.You can machine an adapter if you have the ability. That's what Marks4wd sells for a grand.
Toyota LandCruiser HZJ80 & HDJ80 - Hydraulic Brake Booster Upgrade
