just a plain .txt file. I need to get better about putting entries in it, I usually remember oil changes but other stuff rarely makes it in there.
08/12/1996
Vehicle manufactured and shipped to original dealer
09/16/1996
South Carolina Motor Vehicle Dept.
Folly Beach, SC
Title #027079451A
Registration issued or renewed First owner reported
09/16/1996
Folly Beach, SC
Title #02707945A
10/15/1996
Folly Beach, SC
Registered as corporate lease vehicle
01/14/1998 17,719
Georgia inspection Station
Atlanta, GA
Passed emissions inspection
02/05/1998
Georgia Motor Vehicle Dept.
Atlanta, GA
Title #34085554 Title or registration issued
12/18/1999 44,829
Georgia Inspection Station
03/10/2001 63,786
03/09/2002 76,983
03/08/2003 91,266
Owner 2
Purchased: 2004
Where: Georgia
Est. miles/year: 22,995/yr
Est. length owned: 2/18/04 - present
(2 yrs. 8 mo.)
02/18/2004
Newnan, GA
Title #778533040492027
Title issued or updated
New owner reported
Loan or lien reported
02-11-04 bought 106,000K
Date ? Miles?
replaced coolant, thermostat, PHH, flushed system.
03-21-04, Birf repack, ~110K?
05-15-04, Miles?
replaced fan clutch
08/16/2004 114,262
9-11-04 116,097
Oil change, Mobil one 15w50 Toyota 20004 filter
Rear rotors date? miles?
Relocated breathers 10-16-04
10-17-04 118,800
front diff delo/havoline
trans M1 ATF
T-case M1 gear
rear diff M1 Gear
10-24-04 119,110
installed PCV oil seperator
11-13-04 120,045
Oil change, 5Qt M1 10w30, 2qt M1 15w50
drained just under 3 teaspoons from oil seperator, some water
Removed running boards
1-20-05 125K
installed dual batteries
3-4-05 126,407
Changed oil M1 0w-40
3-13-05 ~126,800
changed front diff fluid, M1, removed and lubed front driveshaft.
3-17-05 ~127K
Rotated/ballanced (5) Tires
4-17-05 ~128.5K
drain/fill transmission M1 ATF
removed and lubed rear driveshaft
5-1-05 ~129.100
hooked up wire for battery switch LED's
flushed PS system, Castrol Transynd
5-7-05 129.905K
adjusted front wheel bearings
removed PCV catch pan
measured front rotors and pads
both rotors >.003 run out
pad thickness
Left outboard .389
Left inboard .403
Right outboard .406
Right inboard .390
5-20-05 130,778
Added 1 quart M1 0w-40
6-8-05 131,848
checked compression:
about 4:30 pm engine shutdown after hard run on highway AC on
5:06 PM
Ambient temperature 88°
CHT 212°
Start disassembly
(Burn fingers, sweat like a dog leaning over hot engine)
5:25 pm start test
CHT 170°
#1 205
#2 197
#3 205
#4 205
#5 207
#6 207
5:38 pm end of test
CHT 159°
5:45 pm start second round
CHT 154°
#1 206
#2 197
#3 205
5:52 pm end second round
CHT 152°
5:53 pm
battery voltage 12.78 main, 12.90 aux, almost no volt drop
installed new plugs, rotor and cap, wires inspect OK.
6-9-05 131,898
Changed oil, supertech 10w-40 + 16oz of AutoRx nippon filter
6-23-05 132,800
replaced original shocks with bilstein
7-8-05 133,738
Changed oil, supertech 10w-40, nippon filter, (rinse cycle)
8-14-05 135,823
Changed oil, supertech 10w-40 + 20oz of AutoRx nippon filter
no notable effects of A-Rx
09/06/2005 137,097
9-27-05, 138,655
Changed oil, supertech 10w-40 + 2 quarts M1 10w-30
10-30-05 141,422
changed oil, 6qts M1 EP 10w-30, 2 qts 15w-50 M1 EP, Toyota -20004 filter
Front wheel bearings play checks good.
battery has troubles starting, need new battery?
date? miles? added 2 quarts oil, one each mobil one EP 15w-50, 10w-30
1-7-06 146,655,
rear brake pads thin (hit squeal tab), temporaily installed thicker used pads
2-18-06 149,030
1 qt make up 5w-30 Mobil 1 EP
3-11-06 149,855
changed oil, Rotella 5w-40 T-Syn, Toyota 20004 filter
Date? Miles?
added 1 quart Rotella 5w-40 T-Syn
changed rear pads, measured fronts, adjusted parking brake
6-19-06
changed air filter
6-27-06 155,000
changed oil, Mobil 1 15w-50, Toyota 20004 filter
09/22/2006 163,039
GeorgiaInspection Station
10-28-06 163,498
new O2 sensors
new air intake hose
new EGR VSV & Modulator tested EGR Valve and lines, Tested OK
11-24-06 164,958
Oil cange Mobil 1, 5qt 10w-30 EP, 2 quarts 0w-40, 1 qut 15w-50
front diff, Shell,
transmission drain and fill Mobil 1,
transfer case drain and fill Mobil 1,
03-9-07 170,402
oil change rotella T-syn 5w-40
