Damit!!! nobody told me I was suppose to right this stuff down.
Victor man...c'mon.....you're a mod. You're supposed to write everything down man!
Here's a paste from mine:
7/3/2005 New Tires 130960 Dunlop Radial Mud Rover 305/70/16 (5)
7/9/2005 Oil & Filter Chg 131070 Switched To M1 10-30 M1 10/30 90915-20004
9/4/2005 Rotate Tires 132962 2002 Miles, 5tire Rot.
12/6/2005 Oil & Filter Chg 134815 3745 Miles, Added Appx 1.5 Qts M1 10/30 90915-20004
12/10/2005 Rotate Tires 134922 1960 Miles,2nd Rot, 3962 Total Miles On Set
12/10/2005 Inspect Brakes 134922 Fronts Appx 6mm To Backing,rear Ok
12/10/2005 Tb Cooant Leak 134922 Spotted During Rot, Cut Back Inner Hose & Sw To Worm Clamp.
3/7/2006 Rpl Dash Pad 136694 Replaced Cracked Pad And Dash Bulbs
3/17/2006 Pack Ft Whl Brg 136859 Grease Black, Tab Washers Scored Seals,tab Washers, Loc
3/17/2006 Rotate Tires 136859 1937 Miles,3rd Rot, 5899 Total Miles On Set
4/11/2006 Rpl Rear Bk Pads 137249 Rotors At .661 Inch. .630 Is Min. 04466-60020
4/15/2006 Oil & Filter Chg 137298 Early Change,switched To M1 0-40 M1 0/40 90915-20004
5/21/2006 Rotate Tires 139003 2144 Miles,4th Rot,8043 Total Miles On Set
9/1/2006 Rpl Air Filter 140850 Swapped Out Trd Oiled Filter Will Clean 17801-61030
9/1/2006 Rpl Intake Hoses 140850 Replaced All Intake Hoses W/trd Silicone
9/3/2006 Oil & Filter Chg 141070 M1 0/40 90915-20004
9/3/2006 Rotate Tires 141070 2067 Miles, 5th Rot,10110 Total Miles On Set
12/17/2006 Rotate Tires 142964 1894 Miles, 6th Rot, 12004 Total Miles
2/4/2007 Replace Belts 143644 All Belts, Including Blower Belt Set Oem Belts
2/9/2007 Rpl Heater Hose 143700 At Rear Of Return Pipe,also T And Hose To Rear Heater And Core
2/25/2007 Oil & Filter Chg 143910 M1 0/40 90915-20004
(All of them from 10 yrs ago -'97 since the LX was virgin
)Dan, so you keep your fields limited to Date, Service, Mileage, and Notes? Any other columns in the spreadsheet?
Dan - How did you crack your dash pad? Was it sun damage?
