How do I handle this?
midwest (iowa)
during painting, a drop of dune beige dripped onto the hood. How do I get rid of this?
Confirm u have base coat clear coat? If so going to be a lot more work. If single stage simply sand with a block until the spot is gone being careful to not take to much paint off around the spot
Get it muddy
x2 on block and sand my kid works at a high end body shop and he has done this for me when my antique spray gun drips
It's hard to tell how much more elevated the drip is off the paint surface in your pic. I really doesn't look very high. So, the razor tool is good for shaving off drips, nibs and runs but you'll still have to wet sand and buff.
I always use the highest grit paper I can get away with that will cut at the defect. You don't want a too aggressive grit or you'll put deep scratches in the finish. Sure it will sand out the drip quicker but you'll suffer trying to sand out deep scratches you just put in trying to remove your drip.
Get yourself a clean bucket of water and add a few drops of Dawn dish soap for lubricant. Soak some 600 grit wet/dry paper for about a half hour. Use a small flat block and in an X sanding pattern, lightly sand out the drip. Don't sand too much in one direction. Also, it's better not to man handle the sanding block with muscle. Go just firm enough to let the sand paper do the cutting.
There is a little orange peel in your finish which is fine. Actually most new car finishes have some orange peel. The down side to sanding out your drip anomaly is you'll be sanding the drip flat to the surrounding paint. Inevitably, you'll be flattening out the surrounding orange peel which you may see in certain light.. If you sand out the entire hood and remove all the orange peel, no one will ever see it. When the drip is sanded out, I'd go over the area with 1,000 grit wet and finish up with 1,500. Wet sanding scratches from 1,500 grit will easily buff out with a foam pad and a light compound.
BTW, is that a PPG paint product you are using? If not, what mfg is it and do you have a paint code.
Rest assured, if you lived close by, I'd come over and take care of that drip for you.
Much thanks and best of luck.
