Im in the process of setting up all the crap that passes through/is attached to my fire wall and was hoping to see some pics of what others have done.
The fw is from an early 70's 40 but the carb on the motor Im using is set up for the linkage.
So far I have to make up a plastic mount/guide since the one on the fw is cracked and a bracket at the carb (aisin stocker) for the end of the housing. Planning to use mountain bike brake cable/housing as the throttle cable and I might incorporate a barrel adjuster to have a little adjustment in there.
Ive seen the set up trollhole sells but since I have everything I need to make my own..... Post up some inspirational shots of what youve come up with.
D
D
