I will try to video with the timing light, should be ~12*, we verified at the beginning of this journey.What is your timing set to? We still need to verify and dial that in.
I had a few successful short drives last evening, I plan to get back out today for a longer up to temperature drive and check again after full warm up!Hold off on panicking or calling Holley! We’ve taken a week to to do a 20-30 min process.
We keep stopping right before we have the chance to see it work or not work and then have to start all over from scratch each time because we throw in the towel
It’s time to lock in and focus and be a dickhead about details mattering
It seems close now. The IAC is tracking with warmup conditions. There is more data to support it working properly than there being a problem. The throttle blade is a hair closed too much. Needs a little more air. It IS finicky. You can do it.
1) Adjust it hot now, see how close you can get it and then drive it. Check and adjust again. Drive it. See if the IAC stabilizes. See if it drives ok.
2) show the timing in a video
3) This will reveal something
Thank you! I will check that out,Might want to take 20 minutes and make sure that the fuel injector clips haven't broken or came off. It appears from the screen that you're going lean. (AFR in the 20's and 30's) Classic symptom of the fuel injector not being secured. If that's not it, you've lost virtually nothing. It's a "thing." It's happened to me with similar symptoms. I chased my tail for a week trying to figure it out. This is what mine looked like when I got in there. If you do this, just go ahead and run a small zip tie around both of them now. This will give you some peace of mind in the future. View attachment 4118016View attachment 4118017
Until doesn’t and goes back into a running poorly with erratic readings.Of course with this issue, it starts and runs perfectly after reassembly!
It is certainly becoming more perplexing,I'd start from scratch- test coil, load test battery, test alternator, test compression, timing, plug wires to correct cylinder, dist cap/rotor in good shape, valves, vacuum leaks, fuel pressure, wiring hygiene.......
What does recheck entail?It is certainly becoming more perplexing,
This morning I rechecked the wiring and vacuum leaks, changed out the IAC valve for the original one and dialed it back in to range (I had replaced it back last Summer during the initial diag) reran the wizard, all with the exact same result.
I have just gone back over the wiring and connections, confirming they tight and clean, for vacuum, I use carb cleaner. A couple of times I was able to do the checking process while it was running poorly to see if I could get anything to change, no luck so far.What does recheck entail?
Whats your voltage look like on a multimeter?I have just gone back over the wiring and connections, confirming they tight and clean, for vacuum, I use carb cleaner. A couple of times I was able to do the checking process while it was running poorly to see if I could get anything to change, no luck so far.
Good suggestion, I will check that when I have a chance.Whats your voltage look like on a multimeter?
