- Joined
- Jul 8, 2004
- Threads
- 110
- Messages
- 1,355
@74fj40, What are you using for RPM input?
I bought the basic sniper kit with no fuel kit as I had a pump and 3/8 delivery and return already. It’s recommended to have 3/8 return so there are no restrictions so that’s something to keep in mind. Also an intank pump is recommended but not necessary. I also had an air filter from the tbi setup, so that is something else you’d have to source.
Sniper kit-$850
90* and 45* -6an fittings-$20
Throttle linkage and misc clips-$50
Misc gaskets-$20
Cap, rotor, wires-$35
Misc loom,connectors, relay- $30
CAN cable for laptop tuning was $50 but I haven’t used it yet. I will though as I’d like to use a tablet for my gauges.
I’m sure I’m missing a few things, but I’m all in for about $1000-1100. It is truly worth every penny. It’s never run this well before.
I spent probably 2-3 hours on it a day for 1 week straight and had it running. There were a lot of small projects I did at the same time, mounting wiring, getting some other circuits run through the fuse box, mounting relays and a new remote power junction. Cleaning up fuel lines, relocating fuse box, etc. Since the sniper has an ecu built in, it really inspires you to keep everything else around it clean too.
I think an fj60 distributor probably has a better curve to it for fuel injection. Maybe @FJ40Jim can chime in on that. If I can score a good deal on one I will upgrade. But I’m still a broke dad going to college.
And fj60 distributor also would have the ability for timing control which I would highly recommend once the base fuel maps are dialed in. It seems a little complicated to figure out but can be done. Especially if you can get the timing maps from a good TBI chip.
At this point i only have about 50 miles on it, but I’m happier than ever with it!
Thanks for breaking out your prices and time. I’m also a “broke dad” but not in the college phase. Pretty cool to see the work you’ve put into your truck while juggling family and school.
I think I’ll start acquiring bits and pieces over the next 6-8months and plan for install in 10 months. Thanks again!
I have been following this thread for a while, and have one basic question. Sometimes we do things just to do them. I have been running the Holley 350 I got from Downey, for years, and love it. I have run it on the old F engine, and on my current 2F
What are the benefits of this? Horsepower, torque, or what? If I am going to deal with increased complexity, there has to be a measurable benefit. Complexity doesn't bother me, but there has to be a benefit.
The benefits of EFI vs a carb set up? EFI uses high pressure to inject the fuel vs carbs where the fuel is supplied at a lower pressure and drawn in, so fuel atomization. Carbs have valves, springs and metering screws that need to be tuned and jetted, these EFI systems self adjust on the fly based on inputs from an O2 sensor, MAP sensor, temp sensors and a throttle position sensor. As emissions got more strict, things were done to make the carbs run cleaner like add VSVs and carb warmers, carb cooling fans, etc. All things that probably dont work as they should 40+ years later. While we have chokes, EFI is much better for cold starts, which eases strain on your engine. While a throttle body EFI system is not "modern" in the way a port injection system would be, EFI makes an older engine run more like a modern equivalent.I have been following this thread for a while, and have one basic question. Sometimes we do things just to do them. I have been running the Holley 350 I got from Downey, for years, and love it. I have run it on the old F engine, and on my current 2F
I'll post a few things I appreciate about the EFI. Of course there are downsides that I can go into if anyone likes.
I really like that the mixture for Idle, cruise and full throttle are very easily adjustable. There is a touch screen in the cab that lets you tweak it as you drive. Many benefits to this, in addition to not having to pull the carb to rejet.
Closed loop operation. Uses the oxygen sensor to monitor the current engine mixture and adjusts instantly on the fly. Corrects mixture variations due to altitude, temperature, air temp, etc.
Idle speed control. It uses an IAC (idle air control valve) to constantly adjust TBI airflow for a constant idle speed and compensates for engine load, engine temp, etc. What I REALLY like about this is offroading, the IAC keeps the engine idling a the preset speed (up to a point) while I idle over stuff. For example, the 40 will putt along idling down a slight hill, then back up the hill, adjusting the throttle all the time to keep my preset idle speed at 800RPM. This would work SUPER well if you have some good granny gearing.
Speaking of idle speed. You adjust that from the cab with touchscreen slider.
Isn't effected by angle.. inclines, etc.
No vapor lock because fuel is constantly circulating in the fuel system.
And, I think it seems to lug along and not stall better. The EFI will keep spraying in the appropriate amount of fuel even if bog it way down below idle speed. I suppose a well designed carb with correct jetting would do this to, but the EFI seems to work real well lugging along. Just my perception on this one.
Can control ignition timing. (Need special dizzy)
Can control electric fan.
Can control idle speed, fan, with A/C
Nice touchscreen display that will display many engine parameters. RPM, voltage, coolant temp, intake air temp, Air fuel mixture. etc.
Can load a "kill" fuel setting, so Cruiser no go.
That's about it off the top of my head.
It comes at a price though. Time, money, frustration and all that type of stuff.
Also, it's advertised as self adjusting and I think that's a pretty optimistic description. It does the bulk of adjusting itself but there is still a lot to fine tune if you want it just right. I've been fiddling with mine for a year, but I'm the tinkering type, so I don't really mind. 70fj40 can give you a much better idea how well it self adjusts on a Toyota motor.
B.
What don't you like about it?
I'm planning on installing one in a few months. I think what people don't like about it/drawbacks and cons etc. normally tells more about the product than all the good things.
Gonna have to think about this...
Mostly the time. Installation time, tuning time, research time. troubleshooting time. You can spend a lot of time converting it over, like it or not.
Cost. I think the price is pretty good for what you get. The Sniper setup is really well made and complete and I think it's a good value, but it is a good chunk-o-change.
I don't like having to run high pressure fuel (60psi) and a return line from my fuel tank(s). Expensive parts, somewhat difficult to install (time). I had to reconfigure my aux fuel tank feed to deal with the supply and return lines for the EFI system.
Reliability of EFI over a carb? I think a carb is dirt simple and reliable. If my EFI konks out I'm dead in the water. (I could carry a spare carb, haha)
Various parts that can wear out. Oxygen sensors wear out, TPS, IAC, wiring... I had a bad fuel pressure regulator from the get-go, and Holley sent me a new one no charge. But more stuff to go wrong.
I think that's about it. If I think of anything else I'll add it.
Still VERY happy I made the change.
B.
Question. The return line is mentioned many times. Does this mean I would have to change gas tanks? I have an old tank with only one outlet, coming out of the side, and no return holes or lines.
I wouldn't buy a new tank. Just clean it, let it air out so no fuel fumes are present, then TIG weld a return fitting on.
It might cost you $50 or less if you have to pay someone to do it.
I tried to find someone to weld on my gas tank. No one would touch it. Dont know how to link but heres a easier way to install a return line. Just drill a hole, insert then tighten the bolt.
