OK, what I've learned in my last year using the Holley 4bbl Sniper on my old 327.
Holley Sniper forum/tech-support
Sniper EFI
I was originally considering the FiTech and was doing research on it before I made the purchase. I talked to a guy that had the FiTech and could never get it to work correctly, and said the FiTech tech support was bad. He ditched the FiTech and installed the Sniper, and couldn't have been happier. He said the learning and computer software was better with Holley, and a couple other things I don't recall. This was enough to tip the scales for me to Sniper. I read as of last year FiTech couldn't keep up with production and tech support. This is all hearsay, but my experience with the Holley tech support and computer software has been very good. Don't know about FiTech or if they've caught up.
Getting the Holley USB "dongle" allows you to plug the EFI into your laptop and give you a lot more flexibility tuning and many more options, if you want them. You can monitor engine parameters and make correction in real time. Very slick.
CAN-To-USB Dongle
BTW, I highly recommend this website for questions and purchases. The owner seems to be one of those honest, straight-shooting and knowledgeable people that stands behind his products. No affiliation..
They had a run on damaged fuel pressure regulators, therefore I suggest getting a fuel pressure gauge to confirm the correct fuel pressure at the TBI. This will tell you about fuel supply adequacy, fuel pressure regulator function, and having an adequate return line. If any of those are off it won't run as well. Holley shipped me a new FPR at no charge.
Fuel pressure gauge info:
High Fuel PSI - Page 5
Speaking of fuel return lines. It's necessary to have a good flowing return line from the TBI. Any excess back pressure will increase the fuel pressure to the TBI that same amount. I had to replumb my two fuel tanks and selector valve to correct this. One solution (I haven't tried) is to add a remote pressure regulator, and delete the long return line. Seems like a pretty slick way to do it, but there are a drawback or two.
Holley EFI 12-875 Holley EFI Filter Regulator 3/8" NPT
The TPS isn't water proof so don't aim a hose near it. I found this out the hard way.
These EFI components, TPS, Oxygen sensor, IAC, etc are available off-the-shelf or from
Amazon, at a cheaper price, than from the Holley website. You just need to do a little research to find the compatible item. There is a list somewhere on the Holley forum.
On some application the Sniper will make a loud whistle noise at certain throttle setting. This can be corrected with a 1/4" thick or greater 4-hole base gasket (2-hole, for those of you with two holes). Had some discussions online and someone finally figured it out. And my youtube video of the whistle.
Throttle tip-in can be abrupt on some vehicles. Making a simple throttle arm extension at the TBI can correct this.
Accelerator Pedal Very Touchy
The Sniper does timing control. I already had my big-cap HEI dialed in nicely, and am not using the control. Timing control would be pretty sweet though. People seem to love the ease of setup with the Holley duel-sync distributor. Not cheap though.
Distributors
You can install the Sniper software and look it over without actually having a Sniper. Kind of gives you an idea of whats going on. Also available here are installation manuals and all that.
Tech Resources
Well that's all I can think of at the moment (thank God)
Hope it helps,
B.
Oops, first impressions and overall results.
first impression: Wow, nice quality, attractive, and very complete kit!
overall results: Great. Took more work tuning and dialing in than I expected, but I'm a little (?) OCD when it comes to that stuff. It will self-tune to about 80 percent great, then it takes effort to get it all perfect. Am extremely happy with it and runs like a champ. Better torque than a carb too, since it doesn't depend on airflow at low RPM to adjust the mixture. It did take quite a bit of work to get all dialed though, not nearly plug-and-play.
B.
