Has anyone tried this high output bolt on nippendendso alternator yet? Supposed to work for 93+ 80 series.
higher output means cramming more into the same case, which means weaker, more chance of something internal going wrong.
Could honestly just be a better design with tighter tolerances and a better design on the windings (with, of course, more turns) and it probably has a slight underdrive pulley.higher output means cramming more into the same case, which means weaker, more chance of something internal going wrong.
There was something I read online that every 20a = 1hp, so it would be up there... I suspect the losses are a little more though. If you need it, you need it and you won't notice those few HP gone. Advance your timing a little and run better gas, or get landtank's MAF to offset the loss or something. You'll survive
No offense meant, but mean green alts are generally considered to be ripoffs. Ohio Generator company will rewind your alternator for max output if you send it to them (and alot of people like the results) and I've heard good things about dominick iraggi, although I have heard his quality may be fading as he tries to meet increasing demand.Possibly but not absolute. Creating more efficiency doesn't make it weaker but it does create more heat. Has the case been ported and the cooling fan been upgraded as well?
I am running the Mean Green 130 amp alt and it actually runs cooler than the stock one did as checked by infrared temp gun. This is a great upgrade and price if it actually is all that is claimed!
Has anyone here tried one of these yet?
