Need to rebuild it and was having a hard time removing it...any tips or tricks would be appreciated
Is the upper hose coming from the reservoir high pressure? It's hard as a rock, lower one is soft
I assume they both come off first before doing anything else
Thought I cracked the 22mm banjo? bolt loose but think the port on the pump is spinning
I have the manual but it's not much help
