Help New owner!
97lx450guy, have you posted in the NC state club area? Depends where you are located, there are very active chapters all over the state and many members ready and willing to lend a hand. Location is:
NC- Olde North State Cruisers
Izzy beat me to it. Post in the club forum. Let us know where you are and we can put you in touch with someone near you.
I think it helps because the other main bugaboo with these trucks is the head gasket blowing. A lot of people think it's in part because the EGR pipe runs really hot and it's really close to the number 6 piston, which is often where the gasket fails. It also runs next to the main wiring harness that is A) no longer available and B) what most of the electrical systems in the truck run through. Getting the EGR system disabled keeps any of that hot exhaust gas that heats up the pipe away from those two areas. My truck runs better than it did before I deleted it, but I am not sure it did anything to the MPG's which are still laughable.
If you live in an area that tests for emissions then you can't really delete it. That could be why they sold the truck as it can get expensive to get that mess sorted out.
Ok thanks for your advice!! So deleting it might save the life of the head? Well I'm moving to SC soon and they don't have emissions so if it will help I'm deleting it.
I'm in Asheville sc but I'm moving to Greenville sc for work for in a month. Should I join both?
Sure, why not? We do a lot of things together. In Greenville you are very luck to have some of the best, world class Land Cruisers shops. Trollhole Cruisers (Marshall Shephard https://towncarolina.com/article/cruiser-control/ ) and Art Stanley with Hardline Fabrication Services in Chesnee. Both members as well and a wealth of information.
This event is coming up, if you can make it, you will meet a lot of the guys too
Trollhole's Annual Part Swap!! July 14-15
You'll have to decide what you want to do. I read a bunch of old threads and I just decided to delete mine and I am just fine with that decision. We don't test where I live though and I left most of it intact so if I need to hook it back up for some reason, I will. Not having that hot pipe back there does make me sleep easier at night though.
The grease you need in the knuckles is Valvoline Palladium (Moly fortified) and it is GREASE, not OIL.
The differential requires gear oil (85W-90) available from any FLAPS (Friendly Local Auto Parts Store)
It will take about 1-1/2 TUBES of grease PER knuckle to fill each side. You should buy a CHEAP grease gun that you can use to squirt it in through the plug in the top. Used for this purpose only.
What you have going on there is referred to as "Birf Soup" when the differential oil mixes with the knuckle grease, then leaks out the knuckle balls. Not dangerous, just messy. It will not "trash" your front end, unless you are working it hard and doing heavy crawling, mudding, or driving in circles at the mall.
Looks like you got the best color and the result of someone that had a "damage multiplier" on the front, rear ended someone, had all the damage except for the front bumper repaired, collected the insurance money, and sold it to you.
Yeah, find someone on the classifieds that is selling a bumper and corner caps for the LX (or buy a bull bar - ARB/Slee/AOE, etc.)
Good Luck!
That's great to know excited to know
Thanks going to def have to check this out! Good to know there are knowledgeable people in the area.
Im going to try and tackle this tomorrow . So glad that there is isn't a major oil burning leaking problem lol. Remember this morning I was was panicking
Good Luck!
Thanks for the helpful information! This is going to be something I get done asap. I really appreiate you sending me this! Yeah now that you say that the hood has an issue closing. A little. The title is still clean. All in all I'm happy. Thanks for letting me know that trash my front end. How often should the dif fluid be changed? Is over due isn't it..?
Im in Black Mountain @sleepycruiser is in Weaverville and @Greenbean is in Mills River and @BillRiley is near Canton and @tnykayaker is in Asheville im sure that we can all get together at some point to help out.
You need to go through the front axle. It's not a CRITICAL thing, just make sure you keep your fluids filled and some grease in the knuckles.
Get the critical things done first to make sure it's safe, stops, goes, reliable.
When the time comes, plan on a full weekend with all your supplies ready and tackle toe front axle rebuild.
@cruiseroutfit for the seal kit and bearings (cruiseroutfitters.com) or local Toyota Dealership
Local FLAPS for lubricants, brake cleaner, and towels
Start reading up on what you need to do. You will learn the obsession.
Diff oil needs changed when it's contaminated or is over about 80K miles. But I would guess yours is due.
From a safety standpoint, check your steering arms and the (4) bolts on the bottom of the right knuckle. Make DAMN sure those are tight! If you lose that knuckle, you won't need the truck anymore. This is a CRITICAL item to check. It is a KNOWN issue that they come loose.
Search "steering arm" to see the fixes and horror stories.
Keep your EGR in the event you may ever move again and need to re-smog.
From another post to another newbie:
To bring with you on the plane:
Credit Card
Insurance Card
AAA Card (if you have one)
Driver's License
Tire Pressure Gauge
A couple 8" long zip ties
Extra underwear
Tyvek Coveralls
Nitrile gloves
Flashlight (or headlight)
Car Phone charger (Make sure the cigarette lighter plug works before you roll)
Download the 96 FSM (Factory Service Manual) to your phone BEFORE you leave!!!!!!!
When you get there:
Go to a local Sears/Ace Hardware/Home Depot/Lowes to buy a basic set of metric tools. Keep them in the package unless you need to use them. Return them to a like store near you when you get home. Also pick up a soft- faced dead-blow hammer, roughly 2 lb.
Check fluid levels on the following:
Engine Oil 5W30 or whatever the PO has in it
Engine Coolant (Should be red or green....NOT brown)
Front Differential Oil
Rear Differential Oil
Transmission Fluid
Transfer Case Oil
Front knuckle grease (This is what the zip ties are for)
Power Steering Fluid (Dexron III)
Other things to check:
Tire Pressures (Including the spare)
Make sure there is a jack, the lug wrench, and the jack crank tools to change a tire
All lights operation
Check age on battery
Grab all tie rods to make sure none are floppy
Check for windshield washer operation (and fill fluid if necessary)
Check condition of wiper blades front and rear
Check the condition of the alternator belts and AC belt. Adjust if necessary
Total quantity of cup holders
CHECK THE BOLTS/NUTS ON THE BOTTOM OF THE STEERING ARM ON THE RIGHT SIDE, BOTTOM OF THE KNUCKLE. THESE MUST BE TIGHT AT 72 LB-FT. ALSO CHECK THE LEFT, BUT THE RIGHT SIDE ARE A KNOWN ISSUE.
Things to stop and pick up before you hit the road:
Engine Oil at least 2 quart, I would do a 5 quart jug
(1) gallon 50/50 coolant of the same color the engine already has
(1) gallon distilled water
(2) quarts of transmission fluid made for Toyota's or whatever the PO has in there
Windex and Paper Towels to clean windows inside
Blinker fluid
Spare alternator belts (Pick up from a store name brand you have near your home....O'Reilly, NAPA, Etc. so you can return the aftermarket belts unused later)
Spare SC Belt
Beer
Water
Ice
Make sure you get a couple phone numbers of members along the route home. Go to the Clubhouse section above and let the local clubs know what you're doing.
Let someone at home know the route you are planning for home. Pot your route on 'Mud for those of us following it.
Post the dates of your expected travel so we know to watch for you (or to go rob your house, whichever comes first....)
Make sure you have 'Mud in your phone as a shortcut. If you need help, post a :RTH Needed, Stranded in XXXXVille, YY..........
All in all, it sounds like you've got a relatively solid truck with a SC and very low miles.
Others that are SC owners know specifics about those.... @NLXTACY ????
Good Luck!
The above items in BOLD UNDERLINE are sarcasm. Don't follow those unless you feel compelled to.
I am in Asheville as well and would be happy to help. I am not super great with wrenching, but I can help with greasing the knuckles, diff fluids, etc. I am pretty good at running stereos, hooking up switches, relays, fuseboxes, etc.
I might eventually have a front bumper from my '97 FJ whenever I buy a new front bumper.
Maybe we can get some guys close by to meet up soon....we haven't had an Asheville meet up to work since January I think. That involved beer and troubleshooting some wires which we eventually figured out... @jdayment @Greenbean @tnkayaker
Ok ! Is the 97 capable of towing a small inclosed
Credit Card
Insurance Card
Driver's License
Tire Pressure Gauge
Extra underwear
Tyvek Coveralls
Nitrile gloves
When you get there:
Transmission Fluid
Transfer Case Oil
Blinker fluid
Spare SC Belt
Beer
Water
Ice
Good Luck!
Credit Card
Insurance Card
Driver's License
Tire Pressure Gauge
Extra underwear
Tyvek Coveralls
Nitrile gloves
When you get there:
Transmission Fluid
Transfer Case Oil
Blinker fluid
Spare SC Belt
Beer
Water
Ice
Good Luck!
Dude thanks so much for all of the advice and tips! Wow thank you thank you !! Really appreciate it more then you know. I will make a list!! Also wondering what SC stands for ? Super charger? Seriously I know I prob sounds lame but I have no idea also is that really low milage I have? Just curious I have heard stories . Guys to be honest I wasn't searching for a land cruiser I was just searching for something within my price range that had 4wd and I love Toyota. So when I found this one and test drove it was the first one I looked at. Very happy with my decision so far just meeting all these awesome people.
Thanks man that would be awesome! I'm down for that for sure. Def would like to learn more about these and other members goals and help them out too!
