Just saw the knuckle, that will be a priority to dig into after the oil is squared away. But dont worry it is just time consuming and messy but pretty stinkin easy-
Ok I figured out the oil is fine. No worries there. It is leaking a little some oil though. Opinions on the knuckle?
Thanks man appreciate the response. Can I drive it for now without any major issues? I want to tackle the pub and codes firstJust saw the knuckle, that will be a priority to dig into after the oil is squared away. But dont worry it is just time consuming and messy but pretty stinkin easy-
Yeah those knuckles look like hell. If you are not going to be servicing them soon then at least make sure there is enough grease in the knuckle to keep them from going dry. Somewhere at the top of that much is a square plug. You can see/fill from that plug.
So why does this occure with the knuckle bleeding? Does it burst or something? I will make sure they do not run dryYeah those knuckles look like hell. If you are not going to be servicing them soon then at least make sure there is enough grease in the knuckle to keep them from going dry. Somewhere at the top of that much is a square plug. You can see/fill from that plug.
Do you have to replace the knuckle how do you service it? Sorry for the lack of knowledge.Yeah those knuckles look like hell. If you are not going to be servicing them soon then at least make sure there is enough grease in the knuckle to keep them from going dry. Somewhere at the top of that much is a square plug. You can see/fill from that plug.
There is a seal way deep inside the axle housing that is supposed to keep the differential gear oil from mixing with the moly grease in the knuckle. If yours isn't clicking when you go around a corner, you probably still have time to just pull the whole thing apart, install the new axle seal and then install new parts back in as you go. You probably don't have to replace the birfield(cv joint), but it might not hurt to swap sides with them to generate a different wear pattern. I would put new trunion and wheel bearings in as long as you are in there. Cruiser Outfitters sells excellent kits that have everything you will need and I am sure others do as well.Do you have to replace the knuckle how do you service it? Sorry for the lack of knowledge.
So I guess I should service the rear too? What about diff fluid? Any other fluids ? The coolant looks a little old, tranny fluid looks good, oil looks to be changed recently. He did use a Toyota filter. Which I was happy to seeOh, no it's easy but time consuming. All you are replacing is the consumables: gaskets, seals, washers, hardware, grease, etc.
I would check around the local junk yards or post a wanted ad in the classified section here. A lot of guys just throw those out when they are installing their fancy aftermarket ones. You should be able to get a replacement for pretty cheap of free.View attachment 1486220 Opinions on the front bumper? Should I take it off?
Thanks for the advice on the knuckle and the video! And I appreciate the advice on the front bumper. Yeah I will post one in the classified section! Thanks!I would check around the local junk yards or post a wanted ad in the classified section here. A lot of guys just throw those out when they are installing their fancy aftermarket ones. You should be able to get a replacement for pretty cheap of free.
Hello my name is Stan. ..... I checked for Rust.
Ok guys was going to ask if the egr valve delete was a bad idea or will it effect milage or anything? Is it hurting me currently?
