1997 lx450
Still learning this forum should have pushed reply. I replied below though.Find out first if it's leaking or burning. Do you have an oil puddle where it sat? Is your exhaust particularly sooty? Have you pulled the plugs to see if one, or more, of the cylinders is oily? Have you checked to make sure your PCV valve isn't stuck open?
Nlxtacy thank you for your reply man!!! . . I just read your reply. I haven't pulled the plugs yet. Could leaking oil cause that much loss? Maybe it could be a combination? If the dipstick reads like a quarter of an inch does that mean that I have basically no oil in the truck? Where is it stored anywhere else?
Ok so I went back to check the oil and its reading half on the dipstick. Could the car have even more oil in it then this if on level ground. Could the car show less oil on the dipstick if it had been running? I'm sorry I'm such a novice. I just feel like I got a good deal and with cars I have had bad luck and so nervous.
Alright. Try to calm down a little and see if you can set up a system for checking the oil so that your results can be tracked.
I would park the car on a level surface and leave the motor off for 30 minutes and then check it. Note where it reads and then drive the car for at least an hour(it can be a shorter length of time if you are really worried that it burned a quart in 50 miles) and then park it again on a flat surface and let it sit for a half an hour. Then check the oil again to see if it's down at all. Really though, a quart is a lot of oil on a driveway, so there should have been a pretty noticeable puddle if it's leaking that much and if it's burning that much, I would expect to see some black smoke coming from the tailpipe.
Thank you guys for your help and patience. Can anyone explain how to post pictures so I can show you guys the truck?
Ok I'm trying to remain calm. I'm in such a fixed budget your ri
Your right. Ok I will remain calm. I just have such high hopes and little $. Ok so I'm still on an incline slightly about 20-30 degrees. And it's reading half. It is def leaking oil but looks to be a small drop. When I filled it after the test drive we had driven it for about 45 minutes. I really want to make sure it wouldn't leave my wife stranded or run hot. I don't know anything about oil pressure but it jumped when I gave it throttle and went up and down. And I had a good feeling when I bough it and I trusted my gut. Ok so back to the point. Yesterday after test drive Could I have gotten a very inaccurate reading from the dipstick after driving it for that long? And as well yesterday after letting it run for 5 minutes. And checking on the slight incline. Could it have read low on the dipstick just from driving and then cutting the engine off?
