Help New owner!
My situation is that I have a little savings but it's for emergency and I have a dependable Toyota truck that I drive daily. But I would like to sell my truck and this be my daily driver. I would like to make sure this truck is maintained and I would like to fix anything broken. I'm not afraid to get dirty or learn new things. That being said I just am a novice in these fields and I'm glad that there is an awesome community with the knowledge and passion available for us.
The good news is that most of the common issues that people have with these trucks are relatively easy to fix with a decent set of metric tools, a set of jack stands and your time.
The first thing I would obtain would be either a paper copy of the Factory Service Manual or download one from here. This will tell you how to remove, rebuild or replace pretty much every component and system in the truck and next to this website, it will be your most valuable tool. I am not a mechanic by trade, but I have been able to complete some of the more complicated tasks like pulling the head and rebuilding the top end of the motor with the help of the manual and especially all of the folks here. Without them, I suspect that far more of these trucks would be in the boneyard. Learn how to use the search function to find earlier threads where people have had the issues you are having and if you don't find the answers, don't hesitate to start a new thread asking for advice. Most of us here are more than willing to help if we can.
Well, you can definitely do you own work on this truck. However, it is a 21 YO truck. It gets horrible gas mileage and they're slow.
If you bought it because it's a "cheap truck" you MAY be disappointed.
Consider you will be buying tools, parts, and maybe the occasional shop repair to do something outside your ability.
Most of us that have, use, and drive older vehicles like this have more than one to compensate. Personally, I have 6, all of various makes and types. 3 are Daily Drivers (DD) and 3 are recreational. My NEWEST one is 1998.
I like doing this. It is my "therapy". It is both a cause of stress and stress relief. The truck doesn't talk back, when it's broke, I can fix it, when I fix it, I enjoy driving it.
If you're going to get rid of the other Toyota to eliminate a payment, buy a s***box Camry or Honda Civic or something to get you to and from the parts store when you need something for the LX.
The LX can be VERY reliable and last a LONG time with PROPER maintenance and GOOD parts. These trucks tend to spit out aftermarket parts and only like Toyota Parts.
Every night before you go to bed, read every post on 'Mud for a minimum of two hours. This will give you a feel what you need to do and where to look.
SEARCH is your friend. Learn to use it.
So why not just throw another quart in, oil isn't exactly expensive.
If you on a fixed budget then you gotta do a lot of reading here and do all the work yourself.
Although the first thing I would do is changing out the PCV valve and dizzy o ring, 2 biggest cause of oil lost on these things.
Ok I will check out the dizzy o ring. I'm ordering some pets now. Will a aftermarket pic valve be adequate?
I would just get Toyota parts if you can. Get to know your local parts people at the local dealership. My guys are awesome and I have bought enough stuff from them that they now give me wholesale pricing and they have never charged shipping.
If that isn't an option, try some of the dealers here. Lots of really knowledgeable folks that know the products and will offer good prices and great customer service. I do a mix of both with the occasional ebay or Amazon purchase thrown in. I try to stick with Toyota parts unless it's either not possible to get a new part, there is a cheaper aftermarket option that will serve the same purpose or in a few rare cases, an aftermarket part will be better, like in the case of a power steering cooler.
Ok thanks for your advice. Im going to check the oil level now it's on level ground and has been sitting for 45 mins. I wonder if I should go ahead and change the spark plugs and wires along with the o2 sensors which are throwing a code, the pcv valve, also have a code for po401. Egr.
Baseline. It's a word you need to embrace.
If you don't test for emissions in your area, the easiest way to deal with the EGR issue is to simply delete it and trick the computer into thinking it's still there with a jumper wire. It's super easy on the '93-'94 models and only a bit more complicated with the '95-'97 models that have OBDII.
Plugs and wires are always good to at least check.
Per usual, @NLXTACY is right about doing a bunch of baselining and of course as @BILT4ME says supporting the vendors here when you can is always a good thing.
Hey do you think deleting the egr will effect anything negatively or postively?
Will it hurt to keep it the way it is?
97lx450guy, have you posted in the NC state club area? Depends where you are located, there are very active chapters all over the state and many members ready and willing to lend a hand. Location is:
NC- Olde North State Cruisers
Just to be clear : parked flat, if just ran let sit for 30 min, pull out stick and wipe clean then re-insert, pull out stick quickish and hold level so oil doesnt migrate all over the scale due to gravity and time, notice the 2 lines on the dipstick indicating low and high and where the OIL line is relative to these 2 marks.
Always keep oil above low line and not over the full line. The distance between the lines represents 1 quart of oil only so if your OIL line is exactly between the 2 line marks then you are 1/2 quart low---
Baselining is your new favorite word but dont look at all the money you will spend in total just take it one project at a time and tell yourself it is worth it..cuz it is! These trucks are special ,no joke-
Ok I figured out the oil is fine. No worries there. It is leaking a little some oil though. Opinions on the knuckle?
Nice looking truck, anyway!
Yeah, you are going to need to do some work on her though. Those knuckles look pretty bad and it seems like you are in for at least a thorough tune up to get some of those codes cleared up.
It seems like a great platform to start with though and you said it isn't too rusty, so that will help as far as working on it, but also just as far as not having to replace stuff due to being overly rusty.
