Help me identify my dizzy
Cologne, MN
The dizzy in my July 69 built FJ40 does not match up to any on SOR.
It has no provision for vacuum advance, it has an adjusting knob which adjusts something that I don't know, It has a thumb nut type clamp, and 1 wire.
The gear is shot, and I want to get a replacement, but I am not sure what to get. I got a dizzy from another member, but it is a different length.
Maybe I should just junk it, and get an electronic dizzy.
Any thoughts on that?
I have a 3 /1969, and original dizzy was not that one. It had a Denso label on it and I still have it. I am in process of putting in a DUI on just because ease of use, no points, and better response / mileage. I will always leave my cruiser ability to go back to stock.
That is a grenade disguised as an auto part.
THROW THAT THING AS FAR AS YOU CAN....AS FAST AS YOU CAN. I mean that.
It is responsible for killing THOUSANDS of landcruiser engines.
Do NOT attempt to repair it.
Seriously.
Best
Mark A.
Seriously.
Best
Mark A.
Well thanks for the advice Mark---can you elaborate?
Suggestion for a replacement, HEI or standard?
Mark forgot an important step...
Throw that thing into the bushes, Then throw rocks after it.
Talk to Trollholl. I believe he sells a vacuum advance dizzy. You will need a tuned port though. Call Mark, send in your carb and have a tuned port adapted to your carb or diy the port. There are threads on here that deal with that subject.
Get your Cruiser running, drive out into those bushes and run over that dizzy.
I think he elaborated quite clearly!:eek:
1. It is a Delco distributor, intended for a GM engine.
2. One of those is the reason I got RUFTOYS from the PO for $750, after the PO ruined not one but TWO rebuilt engines with it.
3. I recommend an early small cap dizzy with a Pertronix setup in it. Best of both worlds. There are a number of vendors who can supply you with this, me being one.
4. Pertronix does not work with a Trollhole dizzy...at this time.
Best
Mark A.
So I had a distributor that i got from another mudder. I think it is from a 77 or newer.
Questions???
2 vacuum lines on the advance. Where do they go, or do I need them both???
Ports on the cap? Where do they go???
2 wires--old one had only one. How do I wire it???
I am in a foreign land with toyo dizzy's. Help me out!
Questions???
that's an ~77ish semi-electronic dizzy. Do you have the coil & igniter that went with it?
That is a factory small cap electronic Dizzy from a 77ish 2F. You will need the stock coil and ignitior assembly to run that dizzy.
Hey Mark,
Can you elaborate on the Pertronix not working with the Trollhole dizzy? I have a Pertronix kit here and am waiting on a Trollhole carb and dizzy. My plan was to use the Pertronix in the Trollhole dizzy.
Bryan
Well, that's just great....everything always leads to another part I need.
Can you get those at a local parts store? toyota?
Or do any of you have the parts I need that you want to sell.
I'm getting frustrated:confused:
I have the coil and ignitor assembly for the dizzy you have, or the early dizzy and Pertronix you PMed me about. I will be happy to discuss further business-related questions if you can find a minute to call me at the shop. 818-953-9230.
As for the Trollhole dizzy, it is a copy of another Japanese aftermarket dizzy that also does not fit the Pertronix. They are a composite design that does not mimic any factory setup.
That is why I intend to develop another mounting plate that WILL work with both those dizzies.:)
