Heater Hoses
Missouri
Hey guys my lx is currently at the shop and soon it will have a new radiator, radiator hoses, thermosat, water pump etc. My gut says to have them change the heater hoses as well while it is drained and the cooling system is getting everything else replaced. So my question is would you order in oem hoses and maybe new clamps, or let them cut and make their own pieces? Also I know I read on here to get the front crank seal and maybe the oil pump seal?, while the radiator is out. Im pretty sure they are leaking, are these the 2 seals to get while the radiator is out? Also anything I should be considering while this is going down? Thanks as usual
If the hoses are molded/pre-formed order oem. For shorter straight pieces a quality aftermarket will do. Yes, replacing the oil seal while the radiator is out makes sense.
MoJ, I thought that was the right seal, do you know about the front crank seal? Again I'm going out of memory, and don't have the vehicle to look at. Also can you or anyone tell me how many/which ones are molded/pre-formed? Part numbers by chance, as I dont have a FSM. Thanks again, I would like to get this ordered tomorrow
Yes. Replace the crank shaft seal, oil pump cover seal, and while you are at it distributor o ring. The first two will be a helluva lot easier with no radiator in the way. And you don't have to worry about damaging the fins of the radiator!
Dizzy o-ring, ok. Does that have its own part number as well?
Would love it if someone has all the part numbers for the preformed/molded heater hoses. Also if I am getting the oil pump seal done, should I go for changing the oil pump itself? Or is that costly/unnecessary? I dont know how the pump is supposed to last. Im at 180,xxx
Ive seen a few threads mentioning the heater valve/heater control valve, terms seem to be used interchangeably in context, is a point of weakness. What is this, where is this, and is it something that should be changed while the cooling system is void of antifreeze? Or is this an electronic part?
The distributor o ring has it's own part number. If you are getting parts from your local dealership they will be able to look it up.
Oil pumps haven't been a known failure. In fact, I don't know of anyone that has replaced one. I could've missed it but not aware of one. I wouldn't be thinking about replacing it. If I had the money to do the "while you are in there" at that time I would be replacing the thermostat and fan clutch to the upgraded blue fan clutch.
Yes. Heater control valve is the black module with heater hoses that make a U on the left side of it. Known to get brittle over time. Definitely not a bad idea. I would also do the PHH (pesky heater hose) at the same time. The PHH has an "official" name but don't know it off the top of my head. If you search for PHH it is in one of the threads. It's a relative pain in the butt to get to, thus the name.
Thermostat is slated to be replaced while at the shop. In an effort to control current cost, I will be replacing/upgrading the fan clutch myself in the near future.
PHH was done 2 years ago during coolant baselining, just didn't look good to me, very "bulgey". Is this control valve in the engine bay or near the heater core/s?
Thanks again, anything else?
HCV is at the very top of the firewall right next to the u-shaped pipe.
I just replaced mine with OEM part - takes about 10 minutes - I'd definitely go ahead and do it if I had all the hoses replaced.
That sounds good, is the hcv EXPENSIVE!, or just expensive
Sounds good. Fan clutch isn't a big deal to replace.
The OEM molded hoses are pricey. Expect to pay $20+ each and there are several of them. I was able to get a few gates molded hoses (for other applications) and cut out the pieces I needed for about 1/3 the price. Some people say only use OEM but I've used gates on every car I have owned, some with more than 400,000 miles, and never had a failure.
I did HPS hoses for everything but the the PHH, my PO cut about 2" off the metal pipe that connects the PHH to the HCV hose (boy that was a ton-o-fun) ---I digress. I used the OReilly premium hoses for the ones I couldn't make the HPS hoses work for.
$120ish is on par for the OEM HCV (boy this has escalated into a lot of acronyms). $185 for the HPS hoses, $20 or so the for OReilly, hoses. No leaks after a couple of days getting everything broke in and torqued correctly
HPS? High pressure something
