Heater Hoses
Like I said years and years with no weeping. On high powered high temp turbo charged engines. Not a single weeping problem.
This is why I've been investigating these is for heat protection with a supercharger. However, I do live in a climate that can go from over 100 degrees in the summer to 40 below. I've also been wondering if OEM clamps work well with these or not?
I have used silicon, gates and one of the top end NAPA hoses (apparently made by Gates) .... while they may all give a different sense of security based on your emotional state ... the Toyota OEM are pretty darn good to begin with! Maybe the PHH is best served with silicon as it it apparently resists high temps well. and that is what I used on my PHH when doing the HG ... BUT the silicon stuff is supposed to use the special 'breeze' hose clamps ... and they are a pretty tight fit on the short PHH fwiw
There have been a couple of silicone PHH failures lately. With Breeze clamps. By people that know what they are doing. The OEM rubber lasted 15-20 years for most people. What more does someone want?
It's a difficult enough area to work in let alone trying to make sure you get it perfectly tightened. No thanks.
Any issues/concerns I should have with the extra heat of a supercharger with standard rubber hoses?
I agree, I don't like how the Breeze Clamps fit when next to the block or firewall.
To answer my own question, it depends. You can barely fit an OEM spring clamp over Gates Green stripe. It takes some lubrication to get it over the nipple. It is mildly concerning how they are still almost fully open when you release. I'm not certain if the effects it's clamping force, it shouldn't if you assume a cnonstant spring force. Toyota ships them in locked fully open state, so they don't seem to be worried about spring fatigue.
I would only use these OEM clamps with Gates Green Stripe if you had access to some flexible clamp. I could foresee many swear words removing them years in the future.
I'm a big fan of Venair Technosil hose, it feels much tougher than the SAMCO hose. I used it for the firewall heater hoses and the rear heater hoses near the cats. After 1 year of service, I'm not seeing any seeping from the hose or leakage around the Breeze CT clamps. When replacing the HG last week, I noticed some damage to the SAMCO hose from the Breeze clamps. It has now also been replaced by Technosil.
Vena® Technosil SAE J20R3 Class A - Venair Silicone Hoses
I have used thermopol silicon hose..nice blue with a racy red inner 'tube'...seems to work ok so far..
