Heat Wrapping Stock Headers
I would say that this is a bad idea. It would cause the manifolds to retain more thermal heat than designed for and prohibit them from cool properly.
Wrap will also retain moisture causing rust. I've seen guys wrap thier 4wheeler exhaust only to find it completely rusted through.
A more expensive but more effective option would be to have them ceramic coated inside and out.
I can't imagine that the wrap would retain a lot of moisture that close to the engine. Midpipe, tailpipe where the temp of the exhaust is much lower I could see it retaining moisture. But right by the manifold, it's going to heat that moisture off quite quickly. Besides, the wrap is permeable not water tight.
Will it prematurely age and rust the pipes? Probably. But I can't imagine it's going to have as dramatic an effect as the anecdotal "my friends 4 wheeler" story has.
Might help. I also think the stock heat shields are a little silly since they are full of holes. Paint or ceramic coat, then heat wrap. Don't use fiberglass heat wrap--doesn't last that long and will fill your forearms with "new hairs"
I recommend you google that.....you might change your tune.
I was under the impression that people wrapped headers because it makes the headers get hotter than normal which creates more pressure difference and theoretically makes the headers pull the exhaust gas better. I don't think they help keep the heat down.
From what understand wrap retains the heat and over time make the metal brittle. That coupled with water retention, it's a recipe for failure. I'm no chemist, but I beleive what I see.
Wow lots of speculation in here. haha.
Yes heat wrap would significantly lower under hood temps. Yes you can buy expensive heat wrap that will not retain water and is not made from fiberglass. The manifolds are not some thin steel tubing they are nice solid cast units. Is it possible it might accelerate their wear, maybe? possibly? slightly? but not to an extent that is going to be meaningful in the long run. I bet you would save enough rubber and plastic parts to offset it. ha.
Look at the lava rock wrap from companies like DEI if you are going to do it.
Tubular steel headers are not the same as cast manifolds.
  • Header wraps are designed to keep the heat in the header to improve scavenging of the cylinders. Keeping the heat in the header allows the exhaust speed to remain high. (the right idea)
In this case not looking to scavenge cylinders, looking to keep heat down.
  • Header wraps, by keeping the heat in the header, also reduces the radiant heat in the engine bay.
True
  • There are no header manufacturers that I know of that will warranty their headers if any header wrap is installed on their products.
We aren't talking about headers.
  • In most cases the header wrap damages the headers beyond repair. (I will explain below)
Again cast iron not thin tubular steel
  • If you run a lean mixture, you "may" see a slim performance gain using header wraps. A rich mixture may show slim to absolutely NO gain in performance.
Not changing the AFR.
  • If you do not mind replacing your headers and header gaskets regularly, and you like that ugly look of a wrapped header, go ahead and use the heat wrap.
Looks are subjective and you won't see them under the stock heat shields.
All posts from a company selling header coatings.
Here is why you don't wrap your exhaust.
Exhaust Header Heat Wraps - Do Not Use
Thank you @scottryana.
You have outlined my understanding after my extensive research into this subject. I am still wondering if anyone has a picture of their stock manifold after it was wrapped. Due to the the 'webs' between runners it looks like it would be a pain to wrap.
Yes Brett wrapped and ceramic pasted his when he did his turbo build, I will see if I can find a picture.
Any idea how many feet I need to do both headers? Should I also do the collector pipes all the way to the cat or not?
Oh well this does not show the wrap well at all. I forgot he wrapped them with heat wrap, covered the wrap with ceramic paste and them put another heat insulator over that and painted it all with high temp paint. haha.
imag6454-jpg.726200
Again I'm no metallurgist but cast iron my natural is more brittle than steel. Also it's not so much that the wrap retains the moisture. That was the wrong terminology. Condensation from temperature swings is where the moisture is coming from. It gets trapped inbetween the wrap and the metal.
