Headlight conversion 7” round
It does work for the lx450. That is what he used in the last set of pictures.
Wish this worked with an lx450!
As mentioned, yes, it does fit in an LX450. The above pictures are with the setup in my LX.
Always glad to help @kelly saad. Hope to see you again next month if you're in the area.
Like on my 100, I bought these same lights. They are amazing.
I'm in for a full frontal - prefer large mesh with old school toyota emblem - please PM price and timing
Thanks !
Everything on this truck is. A 1000 dollars I swear .
Guess no cool round headlights for me
Hey guys...
For those of you doing the mod, like I am, If you are going all out, check out the Vision X Vortex lights. I just got a set from a buddy and they are incredible.
Plus, if you go to Headlight Revolution, they have the chrome (i know :( ) on sale with the Hi-Four adapters for $479. I don't have any affiliation with them, I just saw that they had an incredible deal. Ive seen them in person and they really are better than the JW Speakers and Truck Lites. I don't think they are worth double the price they normally are, but for $100 more they are.
@kelly saad
I loooove the finished product!
I am down to spend on just the 7" round retrofits. Though I agree that buying the grille + round light retrofit combo gets you a better overall look, right now I can't justify that total cost. Any ideas to make the bezel work with a stock LX grille? I am totally fine with cutting my grille in these locations to make this fit and look right:
What if I took one of your stock Cruiser grille headlight bezels, and cut off part of the side til it fits smooth with the LX grille, is that an option ya think? Or if you made one and extended the edge where the headlight bezel will meet the grille an extra amount so I can just cut it to match the LX grille contour?
It looks like you have the form factor of the LX grille figured out since you offer grille only options for the LX on your site.
You tested with an LX right? Is there a mounting tab or anything in that region that would make this not work?
@kelly saad
I would make this work if I knew enough people would buy it. The problem is the inner vertical frame, it’s right in a bad place for the Lexus grille. I can move it, but it will create other issues, and that takes so much time. I just need to know at least a few people would buy it, then I would invest time. Right now I am too busy for anything else. Thanks for the idea though, I will keep it in mind.
OK, Cool. Do you think if I bought the 7" round retrofit pieces designed for your custom grilles and welded a length of 12 gauge "extension" piece on it, I could work the metal and make it fit against the edge of the LX grille? I don't mind a little cutting, grinding, massaging etc. Or does the same mounting issue you mentioned still rear its head ya think?
I am jonesin' bad for these roundies!
