Head bolt threads on new block not deep enough?
Miami, Fl
Hello guys, I just bought a new 1FZ-FE block from Mr T. and had the head rebuild. Installed new OEM head gasket, bolts and washers following the FSM torque specs.
After finishing the installation we turned on the engine for less than an hour and whent for a ride around the block the next day (less than two miles)
We checked the oil and a little bit of colant has gone to the oil. We removed the oil pan and found coolant drops on piston 5
We tried the re torque route but at the first try one bolt broke and the rest didn’t even turn. Lucky for me the broken part was still attached to the bolt. We removed all the other bolts and compared them with a couple of new bolts that I had left and they all were between 2 or 3 milimeters longer than the new bolts. The FSM mentions the diameter of the bolts, not the lenght (or I didn’t see this part)
I spoke to the machine shop to ask about the head and they said they barely shave it and that I could use the OEM gasket. They also said that the threads on the new block might be too short and/or the block might have some imperfections. Any history on this?
About the torque for the OEM bolts, I read many times that what the FSM says might be low but I haven't found any information on the recommended torque value
Thanks in advance
You used new OEM headbolts and first torqued them to value and then to yield? (Torqued at 29 ft lbs then turned 90deg then turned 90deg again)
Did you forget to install the head gasket??? Crazier things have been done.
You would expect there to be more room than that for bolts. Like, half an inch more at least.
Didn't the FSM also call for brushing the bolts in ~30w oil?
Did that happen too, or did these get torqued dry?
FWIW my 1st encounter with the FSM was a HG job & mine was done only to the letter of the FSM, no after issues.
You are correct:
Thanks in advance
Anyone who says the FSM torque values are low doesn't know what they're talking about. The torque listed in the procedure sets the bolts so that they can be stretched. The installation method causes the bolts to yield, or stretch beyond the plastic limit, so that they can't return to their original length. This is the accepted method of tightening critical fasteners, in many industries.
Everyone who posted here is correct. Listen to them and ignore other "wisdom".
I used ARP studs when I did mine. I chased the bolt holes out several passes and when I threaded the studs in, some went in by hand and some had to be threaded in using an Allen wrench. This tells me that cleaning the bolt holes out thoroughly with the block in the frame is not feasible and I don’t believe that achieving equal torque on all head bolts is possible.
This was my experience and I’m not implying that using bolts will absolutely render undesirable results. The ARP studs were cheaper than oem bolts and about the same price as head bolts that come with a fortune cookie.
Precisely why I would not consider re-using a TTY head bolt no matter what.
If would help I could go down the street and measure the depth of the holes in a new short block.
Well, technically, depending on the degree of plastic deformation specified by the procedure, there may be a fair bit of extra headroom for strain hardening to take place before you get to ultimate strength. This can likely be measured, which is why I suspect the FSM specifies a re-use range for the bolts. Considering that the FSM specifies replacing all sorts of "probably re-usable" parts, I wouldn't say it's the kind of manual that throws caution to the wind, so....
That said, it's a super PITA to replace head bolts. I regret not replacing all of mine when I was in there, even though it's run fine and probably will continue to do so. Next oil change I'll swap 'em.
Wouldn't hurt to chase the threads in the block. Be sure to use the washers when installing. Don't over oil the threads in the block or you will hydro-lock your head bolts when torquing them.
Be sure you are turning the bolts (to yield) 90° (twice to achieve 180° total). Some folks confuse 90° and 180°. Big difference between total yield of 180° and 360°.
Interesting. Being you replace your Hg every oil change, I can see where you would want to get as many uses as possible from each bolt. :D
I regret my decision to be the head gasket guy now
I chased the threads too, wanted to do my best to make "all things as close to equal"-as possible.
ARP studs are the only thing I didn't do - only because I wasn't aware of a 1FZ application at the time.
-I agree entirely that stud/nut is going to give a more consistant & accurate TQ value, and if I ever re-work any 1FZ again my own personal 80 would wear the ARP stud/nut HG fasteners.
