bleh
Nice!!Seen a lot of people get the trail gear sliders (250/300 bucks? Watch the sales!) and mod them to fit. I was gonna go that route, but to fabricate the modified legs, my time, my fabricators time and cost, it was the same price to get the sliders from Slee. They were 800, but came with EVERYTHING I needed, and powdercoated which was a plus over a squirt of Rustoleum. Pricey, but bolted on, and welded afterwards. Also has cat conv guard as well. You can build a pkate/tube bumper for a hundred bucks in materials, and a weekend of labor. Rear is about twice as much if you want rocker panel protection, and add another hundred to three hundred for a swingout or drop tire carrier. There are many ideas posted on here, and I took mine, added some key things I wanted and ended up ok in my mind. I used a sub par hinge on my tire carrier, and it failed, luckily in my driveway where no one was hurt or anything was damaged. Already got my idea, just need to knock it out. Here's what I did. New rear crossmember and gussets, tire carrier modified, Jerry can mounts, tubing, I'm into this about 300 or so, and another 50 to redo the hinge the way I want. And the tubing in the sides in not included in that price. I bartered some wheels and a bit of cash for the rocker panel tubing. Ask questions, pick brains, get the info and dive in! Cheers!View attachment 1219196
Do you play in tight rocks or trees? Kick outs are nice to have, if you do, but not absolutely necessary.are the kick outs really necessary for an 80? does the rear quarter panel flare out that much?
Remove the hitch if you don't use it. That will buy you a ton of clearance. If you're going places where you're worried about departure angle then you're probably in places where sliders would come in handy. Rockers are A LOT more expensive to repair than the rear end.I know will probably look stupid, but should i go for a rear bumper first for a better departure angle? Ive already scraped the factory trailer hitch on a failed climb attempt.
