H55 5 speed and late model transfer case
several vendors will sell trans/transfer units, bolt in ready
valley hybrids/cruiser brothers,
cruiser outfitters,
cruiser matt
or any Toyota dealer can get the parts
Have you looked in the classified section? I think there's a few ads in there. Or have you search those part #'s on this site or on the internet? I think the vendors mentioned should have what you want.
Still available brand new from Toyota as mentioned above (I bought a new setup from @cruisermatt). I'll be selling my used one, but the transer case shell needs to be replaced. Unfortunately, shipping to you would be silly.
you're only an hour from Valley Hybrids drive over and pick one up
@orangefj45
Thank you sir.
He’s reached out to us.
Georg @ Valley Hybrids
PS: as mentioned multiple times in the past, I’d HIGHLY recommend buying a new 5-speed, not something “used”. The use transmissions are typically shipped over here from the Middle East or Australia and are usually completely worn out. Hardly worth fixing.
Totally agree George. Ask me how I know.....
They’re ALWAYS junk. High milage & completely worn out. At this point, we don’t rebuild non-U.S. H55F transmissions because you end up having to replace a number of parts, add labor and a rebuild kit …… you end up close to the cost of a new unit. And you still have a transmission with a gear set that has hundreds of thousands of miles on it. So they’re noisy. Absolutely not worth it.
I will add, all new h55s will come with fj60 top plates. If you locate one fj40 jump on it. They are hard to locate.
Correct.
The H55F 5-speeds are still available new with the 10-spline “gasser” input ( F, 2F, 3F, 3FE and early 6-cylinder diesels; H, 2H and 12HT ) as well as the “short” fine-spline diesel; overhead cam engines ( 1HZ, HDT, HDFT and HDFTE )
Both versions come with the rearward shifter location since they’re meant for the 60 & 70 series cruisers.
The “long” fine-spline B-series H55F was discontinued years ago.
We have good used OEM and “reproduction” 40-series top covers in stock.
Georg @ Valley Hybrids & Terrain Tamer
Georg set me up with the H55F and 3:1 LR split transfer case and Toyota parking brake on the output side of the case.
