- Joined
- Jan 6, 2012
- Threads
- 342
- Messages
- 10,986
Some mail-in LS ecu tune companies charge you for the first tune, then any further tuning needs is free. I use black bear performance. Their tunes are all dyno tuned.
The computer will need to know the input and output of the tranny. If you didn't get a 2wd 4l80e, I am pretty confident you'll have to put a reluctor ring in the bottom of the trans. It's at least a question I would ask Holley before getting too far down the road. A stock ECU is a must.
The good new is, it isn't that difficult to pull the guts and put it all back together and the ring is only $35. My notes from doing it....
Impending Vortec Swap
forum.ih8mud.com
Okay, a few months later I did the homework to understand what @lazy meant by this. For posterity:
The Holley Terminator X Max transmission control harness has three plugs for the trans: a main plug, a turbine speed sensor, and a vehicle speed sensor. If you have a 4l80e from a 4wd, as Marks recommends, it won't have a VSS or the requisite reluctor ring. A 2wd transmission will, but you'll need to cut the output shaft to size or install another shaft.
The Novak Guide to the GM 4L80E Automatic Transmission - https://www.novak-adapt.com/knowledge/transmissions/automatic/4l80e/
Here's a guy on YouTube installing the reluctor:
I'm going to take my 4L80e to a transmission shop today and have them install one, plus give its internals a once-over since it's new to me.
Sounds like you're good to go.See I am confused here. Is it saying a 91-96 4wd has the sensor needed. And 97 up needs it installed ? I have a 91-96 4wd model 4l80e It has both sensors pictured above.
@JohnnyFish I'm having a hard time deciding on motor mounts. I like the idea of the ones from The Landcruiser Shop, but they aren't adjustable. If they've found the perfect placement, that's fine, but it seems like a big if. They also don't use the OEM LS mounts, which I've heard suggested repeatedly. Do you have any opinions on this?
I believe (and Jonathan Ward has said this on his videos) the best option is to use OEM mounts and fabricate a connection from them to the LC frame. The vibration isolation engineering that went into those GM mounts can't be duplicated. Of course this method requires custom fabrication by someone who can cut, shape and weld thick steel plate. I don't have a 220 welder.
The LCS mounts that I bought are very well designed and built, and they do provide for a bit of adjustment. I recommend them if you don't want to go the custom fab route.
No, but that doesn't mean much. : )I appreciate the feedback. Fabrication is definitely do-able, just trying to take the easy route where it makes sense
Have you seen anyone else on here who used the mounts from The Landcruiser Shop?
@cruisermatt makes what you need.@JohnnyFish I'm having a hard time deciding on motor mounts. I like the idea of the ones from The Landcruiser Shop, but they aren't adjustable. If they've found the perfect placement, that's fine, but it seems like a big if. They also don't use the OEM LS mounts, which I've heard suggested repeatedly. Do you have any opinions on this?
