getting fumed out!
Weatherford, OK
my 40 is about to choke me out with gas fumes inside. I'm not finding any leaks anywhere around the tank. Is there supposed to be some venting or something i might not have or vented cap? Help!
Behind the left rear wheel. But this is raw gasoline not exhaust fumes.
Is it a steel or poly tank?
You might want to PM MADDMATT. Before i bought my 40 from him it was doing the same thing. I guess it was the poly tank.
Switching to a stell tank must have cured it. I don't get any gas smell now.
If it is an aftermarket Poly tank, re-seal around the sending unit.
Otherwise, or if you do not know what tank you have, you're going to have to pull the seats and gas tank cover out to see what's going on.
There is an evaporative emissions device and a few hoses that may be leaking gas fumes into the cab. Also, your tank could just be shot or in need of repair.
I had the same problem, mine was the fuel pump, it would only leak raw fuel when the engine was running, once you stopped it would only leak a bit until the presure was released. Since it leaked onto the front axel you never saw it drip. Took me forever to find that. Replaced it and my stink went away.
X2 blue Flame, If this turns out to be your problem pay careful attention to the replacement fuel pump. Some require a spacer depending on model. I'm not well enough versed to describe in detail. Someone may chime in with a good explaination regarding this, or just search for a thread on "fuel pump".
Sunday was the first time I completely filled the tank since I've owned this one. It smells all the time now running or not. It is definately inside the cab not under the hood. There are no signs of leaks, however I am yet to remover the seat and tank cover and really look it over. Will do this in the morning and if anything's funny you guys will hear avout it. Thanks
Yep, pull the seat and have a good look around and go from there.
Oh yeah, please don't smoke while doing this!
:smokin: KABOOM :skull:
Take a good look at the filler neck and hoses in that area. Maybe it leaked there and ran down the outside. Is now sitting under the tank in the well and outgassing. Have to remove the tank (easy) and clean it up.
OK. pulled the seat and the tank cover. The leak is around the filler neck on the tank itself. Someone has attempted to fix it by braizing of all things, but to no avail. It's not a bad leak as far as liquid goes but vapor is another story. Is replacement the only option and if so who's the best scource?
Brazing is a decent way to repair it. Welding is probably better. You can get it welded. Requires some know-how to purge the fumes. If it were me (and I didn't weld) I would carry it to some welding shops and get an estimate. New tanks are hundreds of dollars.
CCOT is supposed to have a steel oe style tank available July 31 for $200.00. They also have OEM Toyota tanks for around $400.00. Everyone else seems to only have poly tanks in the $160.00 range. Might just wait for CCOT. Nervous about welding.
Rocknroll said:
. . . Nervous about welding.
You and me both. I plan to modify an old fuel tank I have here. Will use a purge gas even though it's been sitting open for 5 years or more. But a freshly used tank is out of my comfort range too. Good luck.
Brazing is a proper fix. Take it to your local radiator shop and see how much they can do it for. My local radiator guy boiled it out, brazed 4 patches on the bottom, sealed it, painted it and pressure tested it for $60 a few years ago. Get a real steel tank if you go for a new one.
I checked with a local radiator guy here and he allowed neither he nor anybody in this half of the state would touch a fuel tank. Looks like a new one.
While on the subject, where does the line on the inboard side of the tank that comes out the center of the tank wall run to? Mine has been plugged.
