getting fumed out!
theo said:
You and me both. I plan to modify an old fuel tank I have here. Will use a purge gas even though it's been sitting open for 5 years or more. But a freshly used tank is out of my comfort range too. Good luck.
don't be nervous... https://forum.ih8mud.com/showthread.php?t=85731
I modifed a daily used tank and survived to tell the tale.
there is a big difference between drilling and brazing a tank.
Personally, I think it is risky, but if you want, try running a hose from your exhaust into the tank and let your car run for about 20 mins plus.
But on an older tank, make sure it was empty to start with, try igniting any residual fuel that does come out. (Not near the tank) If it ignites, flush well with water, vent for a few days in the sun and then do the exhaust trick before trying to work on it.
May I suggest a little weld it compound?? it does wonders test it out and let it cure properly before you fill it with gas
The exhaust thing Busiboy is talking about is something I have heard of as well. Always best to double check with a pro before messing with fuel and welding though.
true to a degree, but not realy the point... the point more is that a properly prepared tank can be safely welded, brazed, drilled into, grinded on, cut, etc.
It's a very small hairline crack. What about soldering it with an iron not a torch?
x2 the JBWeld. Works.
If I can get the thing clean enough for it to bond that might work
Any ideas on that "return" line in the inboard end of the tank?
i just sort of skimmed this entire thread, but here are a few observations.
1. stock gas tank pads were felt. that eventually leads to pin-holes rusting through the bottom of the tank. bad design.
2. seal-all will work to repair a steel tank temporarily (2 - 3 years). wire brush in a drill to take all the flake and paint off and lay it on thick after you let the tank breath for a day to purge all the fumes.
i fixed mine 3 times in this way until the poly tank became available.
3. poly tanks suck. they are 4 gallons smaller than the already small stock tank, and they WILL leak vapour. it seems like a smart fix, but that is an illusion.
i suffered through arriving at destinations smelling like fuel for several years as a consequence of thinking poly was the trick. not so.
4. the stock OEM tank is the way to go. buy a can of 3M undercoating and spray the hell out of the bottom and the lap seams. use the whole can.
5. for pads, i used the gray clay rope caulk you seal your windows with in winter. repels water. won't degrade.
there you go. stick with a steel tank that you have liberally undercoated. that's my 2¢ after having owned my '78 since 1982. been around the block a few times...
Thanks for all the great advice. Gonna try to clean it up and use jb weld for now. I need some other things for this rig and hate to spend the cash on a tank right now especially if I can buy a couple of years with jb weld.
