- Joined
- Jul 22, 2012
- Threads
- 641
- Messages
- 17,904
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
That plug isn’t used on any FJ62 I have seen.
Thanks. I couldn't find it on any wiring schematic, and searching other 62 threads with undercarriage shots turned up additional confirmation that this is an appendix from...something. Will zip tie it up and out of the way when I get back under there to test the backup plugs coming off the sensor.That plug isn’t used on any FJ62 I have seen.
To this point - the PO had the starter replaced, but I don't recall seeing a ground strap from the starter to the frame. I'll have to check into that. He also had his mechanic install one of those quick disconnects for the battery, which is very convenient but I don't believe it's making good contact with the fender. Will have to check on the strap from the block to the firewall.Failure to ground is the most typical electric problem I have found on our Landcruisers. I frequently have to add a ground wire to parts that appear to be grounded, the biggest culprit is frequently the engine not being well grounded to the frame or body, or frame and body not grounded together. A few well placed wires out of sight once installed will often overcome intemittent and regular problems. I have seen 40s, 60,s 70s and 80s cured instantly with a single extra ground wire. ( i have no idea what problems the 100 and 200 series have)
Reminds me that @ToyotaMatt has a very swanky kit for this..
Nice, thank you! PMing!i am currently Skunk-Work'ing together a 100% Toyota OEM Japan Spec. parts 3FE de-smog kit for GHOST ...
i have explored the current google results on that topic as a whole , and there is no F ....way im sadleing up my girl with a bunch of crumby Chairman-Mao
getto-grade monkey buisness parts !
you are welcome to any of the final take-off parts , currently all that JIS-JAZZ is in good working order , and all present and accounted for too ....![]()
Couple quick items tonight before a busy weekend - received and looked to replace the AT temp sensor, but after pulling off the plug and testing continuity on the sensor in there now, it looks like the culprit might be the wiring or a dirty plug rather than the sensor. Plugged the current one back in, and the light shut off on a test drive. Sort of confused but going to put that aside for now.
Second was testing out the EGR and AI system according to the FSM procedures. Looks like the EGR VSV is busted, no reaction from the VSV when testing with battery power, so that is on order. The AI system all checks out fine, VSV, ABV and all, so that's a good thing. Next is to check the dash pot, which doesn't seem super important as relates to the smog test, but will check it anyway.
That's the one. I do have a used spare at the moment, we'll see if it's needed.ok ,
this IS the FJ62 ATM temp sensor in question right ?
- ignore the color of the nylon housing , focus on the profile / shape topic ONLY , let me know if i got this one spot on or not ?
- i know the broad brush topic at play here , this sensor in paticular , the all OEM parts solution is in my hand as we speek too ,,,
- i DO have ALL the male and female Connetors related to the FJ62 Neutral safty switch if you need any parts of them in any way ?
- if you need a longer or diffent pitch and orf diamiter spring here i MAY be able to help , my giant PLANO single thick clear tackle box os packed the gills with ONLY oem toyota find ir ROLLING on the dept. floor NOS ground scores and beyond ...![]()
- clarify the broken part or parts related to the EGR valve please ?
Valve cover is all installed, with new OEM PCV and associated hoses. It should be good to go.also , you need to examine with a 2x / 5x combo magifine glass both the TPS and AFM / MAF HARNESS side connector plugs , BOTH were in-fact CRACKED on GHOST when i scooped her up ,. no issues untill i changed the UN-KNOWN thin 5w-30 black tar color SHELL ROTILLA convential motor oil that i was so proudly shown multi-tiers of at the sellers shop metal wall cabinet packed top gills of exactly that " Stuff " ....
- have you re-installed the valve cover yet for good ,, as in done ? or is it finger tight loose still ?
here on east coast at least , at Dealership we ran accros alot of the exact scenerio you did upon popping the lid off like that for a un-related but needed reason to do so , and the first time i was finally granted permission by my first ever Team Leader Team i nick-named Sgt. Scrooge, he gave me a actual fundimental hands-on lesson i will never forget and still use when i need to apply it , the results of a full size-spec. HEPPA-BAG use feature HOSE BELOW the lid , NOT part of it HOME DEPOT shop-vac , " little exhaust port Muffler thinngy " installed too is a MUST , you can carefully and more over safely remove end eliminate a solid 97% of any starting point fosilized fossile fuel based motor oil funky-monky crap going on using the picking at it approach you mentioned above , the main rule #1 Sgt. Scrooge repeated more times , all the time was to make dam sure you balled up hard as a soft rock , and plugged ALL possible lower region escape points for the slightest crumb of that crumby crap stuff ...
remember your in the factory owners manual Viscosity Charts 20W50 or greater Motor Oil climate zone all 12 months at your paticular GPS grid there ...fyi this matters greatly , on ANY Land Cruiser engine a and you have found one negative result of NOT obeying this concrete black and white rule printed in any modle year factory owners manual , that black goo , you had to deal with up in the top-end forms in-part from too low a viscosity convential motor oil along with the lack of change intervals factor too , and the overall quality of
the 1989 FJ62 USA-Spec. Glove box owners manual , just like the 1989 FJ62 FSM combined PHONE BOOK size spec/ editiion has the most comprehensive and updated tech and spec. data from 1988 & 1989 Oarnge and White Owner Manual , the 1990 combined FSM is even more wide range better and thicker page wise too , same goes for the 1989- and 1990 FJ62 oowners manual ...
- the one UNICORN loose in the wild and not yet tamed enough for my paper print media knowlege is power one-stop-shop until only just after onlime store open era first Rodeo dayz , is this :
- i did a 5 times blink my eyes take , to process the info on front cover , one i confirmed the Factory Publcation part # was a ligit entity out there at one time and same subjet matter title , i siezed the moment even when not actuaully knowing the full scope of what is was now on my way from the non-usa-far-away destination market region
this in-fact did become and is now even more since my girl the GHOST won my heart ..., one of the top 5 most action-packed relevent TECHNICAL and beyond refrence-resource paper print media materials any thing oem toyota publication #'s in my clutches at the moment , i refer to it and sift through the pages more then several times a week , every week ......
