Gasket question
Reno NV
The gasket set came with 2 fuel pump gaskets, I need to use both? Sorry maybe a stupid question. Btw not a new fuel pump just cleaned up really well.
Second question the little ring gasket, what is that for? I already used the larger one for the oil pan screw but can't figure out what this one is for.
If you use a later 2F fuel pump, it needs a spacer because of the longer arm. The 2 gaskets are for either side of the spacer. F or early 2F pump arm is shorter and doesn’t require the spacer.
If you use a 2F fuel pump, it needs a spacer because of the longer arm. The 2 gaskets are for either side of the spacer.
that only applies to later 2Fs, the early versions didn't have a spacer on the fuel pump
If you have no spacer use only one gasket...do not use 2.
Regarding the O ring gasket...no help. I ’think’ I kinda remember using that gasket somewhere, but not sure. Sorry.
