I have a stock '81 FJ40 with an OEM carb. The truck has 114K miles and I don't know if the carburetor has ever been rebuilt . I'm guessing it has, but I don't know when.
The truck starts quickly and runs well, but just recently I noticed a gasoline smell in the oil. I drained the oil and had a sample evaluated by Amsoil. Sure enough there was a 2.5% level of gas in the sample. I consider this very high because I doubt if I had more than 100 miles on that batch of oil.
I went ahead and replaced the fuel pump thinking that was the likely culprit, but after reading some posts on iH8MUD I realized it might not have been. Just yesterday I noticed that the fuel in the sight glass will disappear within 8 hours of shutting down the truck. I'm guessing the fuel is leaking into the intake manifold and from there gets into my oil.
One other thing I've noticed about the carburetor is that if I use the choke when the engine is even slightly warm, the engine will idle fast, then slow and keeps cycling like this. Maybe this is normal? Anyway, I wanted to mention this in case it helps determine the problem.
Is my carburetor a "gonner"? Is there anything short of a rebuild I can try?
Thanks in advance!
John
Thanks in advance!
John
