SNIP
That having been said, I've had a talk with several Engineers for truck makers here in the US and they all say that more and more, the high margins of safety for component's is starting to be a thing of the past. With higher degrees of engineering and mounting pressure to produce the highest numbers, the tow ratings for today's trucks are very close to the maximum limits on the weakest components. Its not just about cooling, or power, or brakes, or chassis rigidity, or springs, or wheel bearings, etc, etc. Its a combo of all of those things and it will be the weakest link that fails, not the strong point.
True, I understand about that. But you need to remember the 80 was engineered in another age. There's plenty of additional capacity in the system, which the higher overseas tow limits speak to. So in terms of ultimate capability to pull a load, pulling up to that foreign GVW seems doable and without a lot of extra gear. The hitches elsewhere tend to be pretty much the same as here, just make sure it's rated for what you're pulling.
That said, any 7,000+ lb loads pulled with our truck will be few and far between. I've already had my "glad I walked away from that" moment with towing when dad was driving. No need for details, it made a believer out of me. Better have your weight distribution down right is all I'll say. But you should definitely have trailer brakes with any distance beyond a few blocks for those at the limit loads.
Heck, even when our M101 CDN is loaded, I've decided I'll feel a lot better at highway speed with trailer brakes, so it'll eventually be getting a spiffy new braked axle. GVW there is round about 2,000. You can always benefit from trailer brakes, so I'd consider that option for any size trailer now. They just give a significant extra margin of safety.
