There are plenty of differences between the two and the main realization is there will be a decent amount of fab to add FZJ80 axles simply due to the fact you will be moving from a leaf sprung suspension axle to a coil over suspension axle. Which means you will need to determine if you are cutting off the CO perches and adding perches for the leaf springs or vice versa. That is just the tip of the iceberg though.You should search differences between semi-floating and full-floating axles, rather than have someone spoon feed you info. Numerous threads have dealt with this topic.
