- Joined
- Jul 20, 2004
- Threads
- 274
- Messages
- 23,204
- Location
- Chandler, AZ
- Website
- www.tontorecreationalliance.org
That much oil did not come from the combustion chamber of a running motor. Most likely would be the spark plug tube seal, as mentioned. If you do the head gasket job, those seals will be replaced, so should solve the problem, but would be much easier to simply change the valve cover gasket/seal set?
IIRC, all of the USA spec 1FZ heads are functionally the same, interchangeable. There are minor differences, but are relatively insignificant, cosmetic.
