FZJ80 Head Differences by Year?
jaymar
SoCal
Need to pick up a working head to replace mine while saving pennies for a rebuild. Truck was built 6/95. I'm told the head changed in mid-95 (emissions maybe?), but I'm not sure when or how. Does anyone have a breakdown of head changes on the fzfe? Kind of important as I'm in CA...
Thanks for any help!
Difference is sensors for OBD I versus OBD II. If you have an OBD socket built into the top of the fuse box on the driver's side of the dash, then you are OBD II. So 97, 96, and later 95 will work.
Thanks! I am fully OBD-II compliant--so, 96-97 heads EXACTLY the same? "Will work" not good enough for the smog-nazis here in CA. Is there a stamping that identifies the year? (I wanna be able to go back to my original head afterward, and if they see a later date on the backup head, I don't think that's possible.)
Can I ask why you think this will save you money? It seems like the amount of effort to pull a head and then re-install a used head and then do the whole thing over again will probably cost about the same once you consider coolant, the used head, the head gasket, the head bolts, and any of the other non-reusable parts might end up being about the same as just having the head you have gone through at a machine shop. I paid $600 to have my head planed, valves done, new valve seals, pressure testing and even a paint job.
Could you just toss it on a card and pay it back over the course of a couple of months if money is really tight? Unless you are really fast at doing these head jobs, they can be quite labor intensive. I think I had about 50 hours into mine and that didn't include all of the time I spent cleaning and painting everything that came off.
Just a thought...
Just a thought...
I've seen and been told a good head rebuild runs more like $2500 in the Los Angeles area(?)
Sooo the problem is that this is my DD, and as I was preparing to change out plugs-wires-cap-rotor, I found this... (See photo above.)
So I'm looking for a working head to plug-and-play for now.
OK, your problem is NOT the head. It is a valve cover and spark plug tube seals issue.
Buy a VC gasket
Spark Plug Tube seals
PCV grommet
Distributor O-Ring
Throttle Body Gasket
Spark Plugs
Spark plug wires
Cap
Rotor
Cap Gasket
New PCV hose
New TB hose from VC to TB
Any other coolant hoses that may break during the process
TB colling hose under the TB to the near PHH location (because it's a LOT easier to change when the TB is out.
and spend a quality day with your 80.
Should take about 6-8 hours, 3 rolls of paper towels, 6 cans of Brakleen.
Oh boy. I would shop around on that price. Is that to do the tear down and install too, or just the head job?
I can see your possible need, I would just shop around for pricing, Heck, you could send me your head via Fastenal and the round trip for that would only be about $330 plus the $600 to have my guys do the head. It might take two weeks by the time I was able to pick it up and ship it back, with the stop at the machine shop for a week, but that would give you time to do all of the little "while you are in there" stuff. If you could borrow/rent(do they have those handy car loaner programs out there?) a car for a couple of weeks, that still might end up being way cheaper than what you are talking price wise.
Buy a VC gasket
PCV grommet
Distributor O-Ring
Spark Plugs
Spark plug wires
Cap
Rotor
Cap Gasket
New PCV hose
I was just thinking about that as I was typing. Good call. Do a little more diagnosing before going full bore into a head job.
There is a thread here that discussed this issue. The NEW heads will fit 93-97.
The used heads would be 93-97 due to the additional coolant sensor port in the head that the 93-94 do not have. Don't know any specific casting number/part number stamping.
See below.
EDIT:
SEE POST #42 FROM "The Man"
fog machine in my coolant overflow tank video
Buy a VC gasket
PCV grommet
Distributor O-Ring
Spark Plugs
Spark plug wires
Cap
Rotor
Cap Gasket
New PCV hose
Tube was dry before I took the plug out. I am under the impression it is the head gasket, A bad intake valve, or a cracked block. No? Would love to be wrong...
That oil came out of the CYLINDER?
So the tube where the spark plug wire was dry until you unscrewed the spark plug, THEN it was covered in oil?
You're telling me it coated all of that only after you loosened and removed the plug. The spark plugs and wires didn't come out coated in oil. I would think if there was that much oil waiting to overcome gravity right behind the plug that you would have hydrolocked by now.
I am OCD about photographing everything while working on the truck. I shot the inside of each spark plug tube after removing the boot but before removing the plug. The tubes were dry before plug removal. All plugs have oil on the threads. But number five was the disaster you see there. I do not yet have number six because the rubber plug insert in my socket came out and is stuck down in the tube with the plug.
I did briefly start the truck before beginning. Maybe 20 minutes to an hour before pulling those plugs
Please post a pic of the #5 plug wire that fits on the spark plug and if you have a pic down the tube.
That much oil from INSIDE the cylinder is enough to cause MASSIVE amounts of smoke when running or enough to hydrolock an engine.
That shows as classic tube seals leaking.
To get the boot off the plug in #6, go to HF and buy their set of long "dental" picks. Worked well for me!
I have the boot off number six, but the rubber insert inside the spark plug socket came off on the plug and is currently residing on top of it down the tube. Looking for photos. Ah here you go. (Above.) close-up of that boot will follow in hour or two.
Take out all your plugs and turn over you engine with the starter and see what blows out of each cylinder.
Also, I can tell by the pic that the tube seals have shrunk away from the VC.
If there was that much oil in the cylinder, you have MUCH bigger problems that just a head won't fix.
Gotta get that #6 out first... It was prob 30min from photo to #5 plug out, suppose it coula leaked in from head if there's a VERY recent crack in tube. Wishful thinking?
Gotta get that #6 out first... It was prob 30min from photo to #5 plug out, suppose it coula leaked in from head if there's a crack in tube. Wishful thinking?
Sure looks like that's your problem. Head gaskets rarely break in such a fashion that oil profusely pours into the combustion chamber
Wishful thinking because that would mean that amount of oil would be stored in the top of the head, not draining back into the pan, thus, starving the engine of oil.
I don't know where else that amount of oil would be coming from.
I would start by pulling the VC. Either way, you need to check it out to fix it correctly.
I think you stated this is your DD. That's a lot of oil to be coming from underneath. There is nothing above it to supply oil like that.
