Why are you getting such low gas mileage? Seems like what you have is lighter than a full 80 series which don't get great, but should be getting at least 12-14!
1UZ-FE V8 ? Powerfull and lightweight...
Matt is using it for that reason in his 4runner build
Offroad Forum - Die große deutschsprachige Community für alle Offroad-, Allrad- und Reisebegeisterten :: Thema anzeigen - 4Runner
and it sounds convincing to me...
2uz is a better choice.
Same reason I need more power... heavy right foot...![]()
why ? , it weights more, dosn´t it? Horsepower/kg counts...
Ever driven a car with a 1uz? Laaaaaazzzzzzzzy on the bottom end, def not suited for truck use.
The choice seems obvious to me....
In this picture you can see the front of the truck with radiator, condenser, trans cooler, power steering cooler, radiator hoop, factory grille and emblem all installed. The radiator hoop isn't visible with the hood closed - it's tucked up above the opening at the bottom of the hood.
This pic looks like the hard sides fit perfectly. Did you have to extend the hard sides and roof to fit the 104" wheelbase?
What was the belly height?
I didn't drive it today but the frame should be about 19.5" off the ground. (just measured an 80 here with the same springs and added for the larger tires on the 40) It has an extremely low COG and is very stable off road.
