- Joined
- Apr 26, 2003
- Threads
- 255
- Messages
- 5,502
- Location
- Pimpin part in SanAntonio TX
- Website
- www.texas4x4.org
When it's done its for sale
Flammable
Object.
Run away or
Die!
(true story, I used to own a bronco...)
IPOR,
You moved the engine drivetrain back to fit the tire in the wheel well. If I was planning on replacing the front axle/suspension anyway, couldn't I just move the axle forward the necessary 2-3" to fit the axle properly? Or are there other issues that are resolved by moving the drivetrain back?
Thanks.
Lance, allow me to congratulate you on the project, you definitely raised the bar on this one!
I am hoping you can reply to a few basic questions about mating a 40 series body to the 80 chassis:
Did you experiment and confirm the rims and tires you chose were optimal for backspacing? Was there other choices you could have made to reduce the protrusion of the wheels?
I do not recall you mentioning modifications to the axles, other than replacing the E-lockers with air units, is that correct?
Did you retain the 4:10 gears or re-gear for the bigger tires? Was gearing at all an issue on your final satisfaction or was it just not enough horsepower?
In hindsight, would you still go the route of wider fenders and flares vs. widening the tub?
Thanks,
Rick
What's your hard top plan? I took two tops and stitched them together with a pop-out window and a full size combo.
Did you ever weigh the FZJ40?
