FST soft door window pull clips/locks
JohnnyC
昔は TLCA2231 Order of the Pinion Shaft (OoPS)
Sire John @ UpState Ny & Wells Me
TJS8040
I haven't forgot... Been a bit buisy but had some time to fab some... These are not 100% to my liking... I will try to get you two matching and more original in shape.... And not so much of a hack like the shady tree type of guy I am LOL
These are my practice ones... The white one far left is my oem door window pull lock... Probably next week if that's ok
I need one of those.... Can you tell us how you made it? I'll give it a try.
Pete
Pete
do you have one to work from?
If I didnt have one... it wouldnt be too pretty :meh:
I am using some vintage tools... i was told that the bender and cutter i use are from 1959... but most of the bends are started and adjusted the reast of the way be hand... maybe with a newer bender that isnt 'bent' :rolleyes: it would be a bit easier
I am using an old metal cabinet for the metal (recycle, renew and reuse :) ) cabinet is from 1975... so more vintage stuff :D
I have at least one good one. I hope to get the doors on by the spring....... But well see. Things are busy.
I'd love to get a small brake some day.
Pete
I have a set of FST soft doors to restore. They are RUFF! (The price was right though).
I have not checked with Beno but due to the number of softdoor vehicles over seas it appears some of that stuff is still in stock.
PLATE, CANVAS DOOR WINDOW HOLDER ... 68212-60020 FOR CANVAS DOOR
I had checked many moons ago.... AFAIK they should be the same for all years in NA
MIA
BTW the spring for the handle is still available... got one a few years ago
for those who might want to make one from scratch....
starting width is 50mm
here are the steps :)
Pic1: bend #1, 16 mm, it is 15mm plus 1mm for the lip you do last.
Pic2: bend #2, 6mm
Pic3: bend #3, 19mm
Pic4: bend #4, this is the smooth bend starts at about 9mm done by hand
Pic5: Cut at 22mm past the 9mm
last step... clean up and then paint
the one thing that is missing is the plastic/rubber tab on the pull end... i bet plasti-dip would be good for that... have never tried it... but... would imagine it would finish it off really well
Now that is some detailed info! Thx Johnny! You should be a teacher.......
P
the ones i am sending you guys are from the 5 sets in the front row second picture .... PM me your addresses ... i will probably be able to get to the post office next week to send them out... will let you know shipping when they are sent...
Time to give back to MUD...
If anybody else needs some of these PM me or post up here...
How much are they you may ask?
just cover shipping is all i say... if you want to send more $$ I will not argue with ya :)
limited supplies as you can see... the white one is OEM and is on the brink of braking .... so one of these will be for me :D
Window clips
Johnny, I'd take two if you have any more.
Pm sent
Thanks
