Does anyone have some good suggestions for reassembling and shimming the front knuckles with out having the proper service tool? Is there anyway to borrow the tool? Could Toyota or any local shop do this for me?
Toyota part SST # 09634-60013 List price is $112.21 from SPX OTC (800-533-6127)The tool is only used to set up the knuckles once. If you remove the knuckle,put the shims back on the exact way you did the first time. If you do this you will never use it again until you chang out your knuckle or screw up your shim arrangement. Unless you have multiple vehicles to set up, I would try to borrow one from someone. I thing the tool is pretty expensive. Do a search for "sst tool loan".
P.S For my mini disc swap I did 1 thick and 1 thin on top and bottom. This was before Marlins seals so I used standard ones. When I service it next year I will use Marlins seals and hopefully will have no leaks. If they leak after that I may look into this tool. But I figured since I am going to service my knuckles every year anyway, it was worth a shot without it.
Jeremy
