Front End Vibration/Wobble @ 70 mph
Raleigh, NC
I've searched the site for info on the infamous death wobble and other vibrations coming from the front end, but nothing seems to be specific to my problem. Looking for some troubleshooting advice.
Vehicle Details:
1993 FZJ80
150K Miles
OME 2.5" Lift - Heavy front, medium rear, OME steering stabilizer, caster correction bushings - new
285/75/16 Goodyear Wrangler Duratrac - brand new, balanced
I've done a ton of PM recently including:
Replaced wheel bearings
Replaced tie rod and drag link with Budbuilt HD units
Replaced TREs and DLEs with OEM
4 wheel alignment
The steering overall is tight - feels very solid until just over 65mph. It tracks great, doesn't wander a bit.
On the freeway, it starts to develop a vibration/wobble in the front end around 70mph, enough that I can feel it side to side it seems. There is a slight vibration in the steering wheel as well.
Needless to say I am vexed - I don't plan on driving much over 70 anyway, but when I take it to the beach, it would be nice to cruise at ~75 for the 2 hour trip.
Advice welcome - thanks
Have you checked bushings and torque on all 4 pan hard ends? IIRC front sets at 130 # both ends and rear is 130 on one end and 160 on the other.
If all good, then have you checked into driveshafts?
Have not checked Panhard bushings and torque specs - will do that next..forgot to add that I replaced front and rear u joints as well as the slip yokes. Front and rear driveshafts were in balance.
Discount tire, so I presume regular spin balancer. Is the Road Force type machine significantly better or more accurate?
check air pressure, with a good gauge - I have experienced noticeable vibration with as little as 3-5 psi difference on the same surface (the highway down to where inkpot and Tools wrench :hillbilly:)
Check the four studs/nuts directly under the knuckle housings. Just in case...
Also, grab the top of each front tire and shake that mother like a gorilla, in/out! If you feel play, you might want to fix that. Trust me, you can't put any more force into it than just driving it would, so you can't hurt it. Just do it when the neighbors aren't watching...
Not too long ago my truck developed first a mild vibration at highway speed then after awhile a pull to the right. Soon I could not take my hands off the steering wheel even for an instant or I would have ended up over the guard rail. Checked all the above and found nothing obvious until I focused on the tires, turned out to be a defective front tire which had slipped a belt internally. New tires solved the problem, back to three finger driving. FWIW.
Take it back to discount tire and have them check the balance on the tires, it could be as simple as you lost a wheel weight, and that's causing your vibration.
Have it road force balance although it's not that large tire. Don't chase you tale like I did for a year . I just got two replacements under warranty. After a whole year if replacing stuff. Mine are 37's. They balanced fine on regular spin balance a year ago then when I took 80 back I had them road force balanced. Two tires where out of round/egg. It was only noticeable from 66-75 mph. But was quite a shake!! I had to send cutouts with dot number for warranty
Resolved! All it took was a road force tire balance - the guy said he had to add quite a bit a weight to balance the dynamic forces, but I took it for a spin on the freeway right after and got it up to 80mph without any wobble. Still trying to chase down a little driveline vibration between 40-45mph, but it feels so much more stable on the road.
Vehicle Details:
1993 FZJ80
150K Miles
4 wheel alignment
Hey ,I've the same problem with my 1992 ,80 series ,it seemed to develop this issue after a tour of morroco and the draa valley desert , I like you don't notice the problem up to 60 mph but on the motorway (freeway !)at higher speeds I get the death wobble ,I've put up with this issue as we live in south west France and very rarely get much above 55mph !!!.
Have you tried dropping your front property off and taking it for a spin on the freeway with centre different lock engaged ? ,I took mine off when I got back to Malaga from morroco and drove the 1800 mile back to the UK with the front prop in the trunk !!!, I'm sure I didn't get the death wobble but it was 4 years ago bare in mind !!.
Hope this helps because like you it's very frustrating .
Mark
