Front differential
Caused damage?
  • Yes
    Votes: 3 37.5%
  • No
    Votes: 5 62.5%
  • Total voters
    8
I have an unlocked front 3rd I can sell you if need be. 86k on it and the axle it came out of was well maintained.
First, I would check the magnetic drain plug for large chunks or flakes of metal that would indicate bearing failure. If you have a lot of chunks, remove the differential and inspect it more closely. If only fine powder is found, Fill it up and run it.
After sticking a screw driving for a good 30 minute all this came out, by the way there is more I'm there
You should be fine. Flush your diff like the others mentioned, rebuild the axles, and get that crap outa the living room! :flipoff2:
This advice is late for the front, but worth mentioning before you drain the rear.... Remove the fill plug before you open the drain. That way you'll know you can refill it.
Rear will most likely be MUCH better, since there are no knuckles/birfields packed with moly grease to contaminate the axle lube.
Side note: if you don't know what a 'birf' is, you really need to read the FAQ for 80s stickied at the top of this forum. REALLY.
I checked nothing real just grease.
Also, jack one side high to drain axle to pumpkin, then repeat on the other side. Sort axle seals, clean, grease reassemble CV's (Birfs) fill axle with oil, run it a couple of weeks rinse and repeat.
@Pin_Head post is a good thought and somewhat worrying, fingers crossed for you.
regards
Dave
regards
Dave
Thank you bro, I know I hope there is no damage otherwise it's gonna be parked the whole summer
Masud, I hated to see that bowl of "diff soup" that drained out, but at least it had some lubrication. Don't get any of it on that rug or you'll be dead meat for sure. I'm gonna follow the party line, check for obvious metal particles/pieces, refill if appropriate and drive it for a week, drain and refill, repeat until clean oil drains out. You probably need to inspect the birfs and repair as needed. Good luck.
Thanks for the support, yea I'm gonna do that hopefully it turns out to be OK. Actually the carpet is already messy AF, but yea definitely don't want that diff soup on it lol
If it doesn't make any noise, I'd just drive it for a week with fresh oil, then rinse and repeat. I would definitely check the knuckle grease level, and make sure the breathers aren't clogged. It's very possible that there's no damage at all, but you should be concerned that all that grease came from the birfs- how dry are they now?
I took out as much grease as I could, but Im sure there is plenty more in there and I added 1QT of 80w90 because that's all it could take. I'm gonna drive it for couple days and flush it out again once all the grease is out I'll pour in good quality oil.
On the bright side you don't have to worry about not getting the Diff Drain Open.
Get the 2 new magnetic Allen Head Plugs and silver washers (Stealership) fill with 90 Weight till it comes out the top plug. I would repeat after driving 20 or so miles and drain and refill until oil looked good.
Observe if you get leakage out of the eyeballs at the end of the axle.
If you do you get to get super dirty or just hand over your wallet. I recommend the former so you can learn. More help then you could ever need on here and it's all free!
