Front differential
Caused damage?
  • Yes
    Votes: 3 37.5%
  • No
    Votes: 5 62.5%
  • Total voters
    8
California
I just opened the front differential to change the oil and I stumbled upon this. Barely any oil in it only a couple drops. Any ideas if this has caused a lot of damage or not?
Wow, you must have goo in there. Very bad for diff to run low on oil but if everything is covered in that combo of birf grease and oil you might be ok. I'd recommend a refill with cheap gear oil, and change once per week for a month and see if it cleans up. I ruined a ring and pinion driving slowly about 1 mile with no oil in the diff.
WalMart is a good source for cheap gear oil.
What are your knuckles like? My guess is the seals are shot and that your front end needs a total rebuild.
Your diff is most likely done
Eeek! If you haven't heard any strange noises coming from the diff, you might be OK. Agree with both posts above...flush it out and rebuild the birfs. Also check the the diff breather...likely clogged.
Honestly no weird noises i bought the car not too long ago
Happy Birfday and diffday.
You have to open everything up clean and inspect closely. Redo the birfs.
Check everything that runs oil in your rig. Very likely the PO ignored it all. Transfer case, tranny, rear diff, break fluid.
As mentioned above, diff breathers may need to be checked and have the lines extended while you're there.
Are you sure it's not plugged with grease at the bottom? Have you tried sticking a screwdriver or something to dislodge any captive material and see if any oil comes out?
Also was it making a bunch of noise or other symptoms? I would think you'd have all sorts of unpleasant noises coming from the front with no oil.
If there was no oil I would remove the axles and inspect the third member for sure. Running with no oil would definitely cause damage in my opinion. Last thing were there a lot of shavings on the drain plug?
What do you mean by birfs?
You may have gotten lucky and your entire R&P is a ball of moly grease from the birfs (not likely but possible I guess). A birfield and CV joint are basically the same...Birfield is the term used when talking Toyota solid axles. You'll have to rebuild your entire axle...not too tough and plenty of threads/youtube vids.
Actually I just sticked a screw driver in and some more oil came out but the oil is really black and thick
I prefer to have as much knowledge as possible, of the damage before taking it apart. So would fill it with gear oil, put some moly in the knuckles, then drive it enough to know what is up.
Kinda typical, most users don't change it enough, the moly migrating from the knuckles turns it to paste. It often takes several gear oil changes to clean it out.
Honestly I'm pretty unknowledgable on the mechanics of this car but I admire the way it drives and the look of it.
While moly grease from the knuckles is not the Preferred lubricant, it does actually work OK. I would pick up a cheap bore scopre from Harbor Freight to look it over. May need to do a couple of flush cycles first to get it cleaned out enough to see good details.
I've even put regular motor oil in ther for a bit to help clean it all out...
