- Thread starter
- #21
Thanks, everyone, for the excellent feedback. This is why I love ih8mud!!!
Still too much...did you check your breathers? Have any photos of said problem?Asked for clarification from the shop. This is what I got:
"To just replace the knuclke wipers, backing rings, knuckle gaskets hub gaskets, inner wheel seals, inner axle seals, clean and pack the birfiedls, replace the wheel bearings, replace the knuckle bearings and set up the knuclke clearance your looking at right around 2000.00, there still is hardware that may be needed (we recommened to be replaced any time we do a knuckle service as preventative maintinace, if this hardware fails it can cause the steering arm to separate from the lower side of the knuckle and let the wheel fall so the vehicle is not drivable) spindle bushings / bearings that may be needed (most likely will need to replace these as they are usually the cause of the wheel seal leaks to start with), birfields that may be needed. All of which we will no know untill its pulled down."
So $500 of the original estimate seems to be the diff removal and thorough cleaning...
Breather was COMPLETELY clogged. Took it off and forced it open with wd40.
I just gotta........
TOLD YOU SO!!!!![]()
You sure did! Quarter can of WD40 = 70 cent fix!!!!! I'm no math genius, but I'll take $0.70 over $2,500.00 every day of the week!
Now I can spend the remaining $2,499.30 on things like rockers and a proper roof rack!
IMHO this fix should be in the "sticky" for every truck.
... check to see if you have moly bearing lube in there.
UPDATE: just got mine back, and it was 10 hours of shop time+parts to do my axle. One Birfeld was replaced.I was quoted $3500 for a similar repair (SF Peninsula), and had another shop (North Bay) do it for FAR less than that. Seems like you are getting a 'full retail' quote, fwiw.
