Frame strength after welding.
I am fabbing up some sliders on my 93 fj80 and I want to weld them directly to the frame rather than bolt them on. I am using 3/16 2x2 mild steel and it will be a ladder style with 4 attachment points to the frame on each side. I am using 1/8 welding stick so there will be a serious heat issue on the frame at those 4 points. These trucks are pigs and I was wondering if there would be a degregation in the strength of the frame. Let the arguing begin!:popcorn:
If properly done, welding wont damage the frame, but the frame is only ~1/8" thick so would use scab plates to spread the load. Vertical welded ends on the plates have the highest chance of cracking, so would make the ends angled or football shaped.
There is no argument. Look at every piece attached the the frame of your truck. They are all welded on. Toyota sells replacement parts that require welding to the frame. These are not over the road trailers with HSS frames.
However you should be an experienced welder in any case.
I lurk on pirate 4x4 alot and if you say the air has oxygen in it someone will argue:rolleyes:!! and I would assume that toyotas welding robots are a little better than my lincon stick welder and and a short trade school welding class, but you guys have helped me a bit (scag plate is a good idea)
Go for it. I welded my sliders to the frame and added gussets to the top of the tubes where they attach to the frame. I've come down on them hard and after nearly 3 years now there are no signs of cracks at the frame.
No rocket science involved. Welding to the frame will not damage it. I've done it to a 62, 80, and 4runner; no probs. If you used enough heat I guess you could burn through in spots, but if that's the case, you wouldn't have a clue on how to weld anyway.:lol:
Agreed.
I wanted mine to be a bolt on, without using U bolts. Bit more of a challenge there.
It's really hard to describe, but I took a roughly 4"x4" 4 gauge plate that I welded to the frame. I then welded on 1/2" wall piping to that, which then bolts to my slider arm. (Really bad description, I know. :o )
Had I welded the 1/2" wall piping directly to the frame, it would have been very difficult to do without blowing through and still getting a good weld. By doing the 4 gauge plate first, it allowed me to step up (from 1/8" to 1/4" to 1/2"), plus there's a lot of weld around the plate (all 4 sides) which spreads out the load.
My biggest concern is the piping breaking off the plate, but I highly doubt that given the amount of fill there is there. :grinpimp:
Plus, should I ever want to redo my sliders, I can just cut/grind the tubing off and have 3 clean plates ready for whatever.
