Official ONSC member buying/selling thread (8 Viewers)
Hey Johnny, I'm in Charlotte. Anger hater Pm'd me first on some of the items. So he's got first dibs.
Followed by Johnny on the sofa, chair and bar stools
& Al for the washer dryer.
Where are you located? Interested in sofa, chair and bar stools.
what are the specs on the washer dryer??? my sister is looking for some
Al its a standard top load Whirlpool, white in color and the dryer is a matching standard sized front load also in white.
These are about ten years old but weren't used and abused. They have been wrapped up in moving blankets and stored for the last couple of years.
As mentioned above, Angerhater PM'd me first on these but I'll let you know.
4.5 liter 1FZ-FE .... that's a house hold item, right? Just need one.
If most of us cruiser owners had our way it would be. It would make a cool glass coffee table base.
I wish I had a spare engine but if I did, it would probably be all built out and wrapped in plastic in my garage as a spare and not used as a house hold item. Sadly, I have neither.
Oh yeah that reminds me. How's the coffee table coming Johnny ? :D
Yeah, it got nixed by the better half. Gotta find space in the garage for it, aka build a bigger garage, then it'll happen.
Chandelier. Women never look up. And she'll never notice the massive amounts of blocking you've installed to support an engine block.
Pm on the sofa and chair
Does anyone have a spare bottom seat cover for an FJ40? I have a huge rip in the seat and would prefer not to replace all the covers but want them to match.
@Rice I'll toss some in a bag and look for Jason.
Arrived today. Totally perfect. Thank you!! Won't get to that lab until next year since I'm already done with this year's curriculum but will post up some pics when it happens. Thanks again.
Rice
Well i've hinted at it on facebook and talked in length to many at the meet and greet about it but it is time to sell the cruiser.
I've loved this truck for almost 9 years and the reason for selling is my lack of ability to afford to do anything with it right now and upcoming plans that it might not fit in to.
I really don't want to sell but life plans to put Andrea and I in a better life place take priority.... an hey ... there are plenty more cruisers out there to be had or may just buy this one back in a few years ;)
Most of you know or have seen my truck.
Most other 3FE guys that have ridden in it talk about how strong the engine feels compared to theirs.
Mods
Gen II Slee 6 inch suspension lift with adjustable front and rear panhards and adjustable rear control arms.
Slee SS brake line extensions
New OEM bushings put in Radial Arms with under 2k on them.
Bud Built tie and relay rod with new 555 tie rod ends.
Slee 1" coil spacers up front
Custom made sliders
ARB front bumper modified for better approach angle and cleaner lines
Lightforce 240's on bumper
Smittybuilt 10k winch on front bumper (steel line)
39" michelin XMLs mounted on stock FZJ Wheels powdercoated black. Lots of tread left. (Have spare Wheel just don't have a spare tire on it)
Ebay Snorkel
Frame Brace made for steering box by Stan (NCFJ)
Front larger brakes from a FZJ swapped in.
Rear FF from a FZJ swapped in
4.88 Yukon Gears
ARB air Lockers front and rear
Dual Ford Contour electric fans
Slee Headlight Harness upgrade
LED Smoked Tail lights
Super Bright LED reverse light
GTP Hood Vents installed
Replaced recently
New Radiator with less than 10k on it
Brake Booster and MC with less than 3k on them
New trailer wiring works great
Exterior is about a 7 out of 10
Interior is about a 7 our of 10
Extra Parts to go with it.
Have Desmog block off plate
Extra door glass for all doors and sunroof
Spare Birfields
Extra front Axle housing
Extra Transmission with >100k on it with flex plate and tq converter
Should have most of the parts needed for dual battery set up except a fzj80 battery tray cruiser parts.net has them or $35
Flow master muffler off of a 95 80 series (have to pressure was it to get the series of muffler off of it)
3FE TURBO KIT
Bolts to stock exhaust manifolds, no welding needed at all to install, down pipe has provisions for 02 sensors and depending on where you live you could just run it open like that (o2 sensors on 3FE's are before the cats so not running them will not effect how the engine runs)
All inclusive bolt on kit
The bad:
I took out ARB compressor to rebuild it and now cannot find my mount for it or the air block to put back in. Will need to be reinstalled and wired back up to OEM locker switch
AC is out of the truck (was when I bought it) but I have everything needed to reinstall in boxes
tires need to be balanced again (used 4 golf balls in each when installed and they worked great for a few years but most threads say they tend to warp after a while, this time i'd do dyna beads or air soft
When I rebuilt my axle last year I lost the trunion bearings to install so it will need new trunion bearings (I have since found them along with another rebuild kit for the axle I thought I had lost)
Rear main seal leaks a bit, was going to replace when new transmission went it. Nothing wrong with the transmission but a >100k one is always better
Radio goes in and out, needs to be pulled and replaced anyway with the harness looked at
engine bay wiring needs to be cleaned up with dead leads removed and everything else just cleaned (will try to get to this before the sale)
Most likely needs an alignment
At that time that it needs a tune up and most likely valves adjusted again, idles a bit rough but I think desmogging will cure that with a tune up
One cat just started knocking so is bad (not a big thing though because the install of the turbo kit would change the system to a one cat if desired anyway)
missing ebrake cover, I should have one somewhere in my parts pile though
I'm pricing it as fair as I can... it doesn't need a lot of work but isn't perfect either and runs and drives great as is. If I installed the turbo kit and finished the rest price would be over 10k
Priced to sell fast to a ONSC member $6500
PM or text for details.... at work till about 9 so won't be back on here till then
Dang man...I know we have talked about this a lot in the past. Sad and sorry to see you selling it but completely understand.
Damn good price...someone needs to buy this in the club and complete the final few projects/mods to realize the full awesomeness of the Yeti Wagon.
And you pick April 1st to list with the tradition of this club??? :D
It's a good looking rig and priced well. Ill send an email to a friend or two casually looking
Sorry.
Need to clarify. Just found out fj80 stock rims are 15".
I am looking for the 93 and up fzj80 stock rims that are 16". Need 4 or 5.
Please hit me up if you know where there r some.
Are you still looking for some rims??
Anybody in the Charlotte area sitting on a lower thermostat housing for a 1971 fj40. Need to find one ASAP. SOR has them for $80 but would prefer not to have the downtime while they ship. Please PM me if you can help me out. Thanks!! William
I got one. Send me a pm
