For A Dollar A Day…
65swb45
Elder Statesman
Supporting Vendor
Website
marksoffroad.net
In the early years of Mark’s Off Road, I had a lot of counter traffic, and a lot of guys who just liked to hang out. One of them was the husband of my wife’s best friend from college, a man named Robert Hooper. Robert was mechanically inclined; his forte was Honda motorcycles and vintage VWs. He didn’t own a Landcruiser, but he was a cool guy anyways. And he was intrigued by the idea that I had just up and decided to open my own shop, and I think he wondered if he could do the same eventually.
One day when he was hanging out he said to me, “You know Mark, you can get all the mechanical education you want for a dollar a day.” I was intrigued.
I said “I’ll bite. Tell me how you can get all the mechanical education you want for a dollar a day.” He explained that it only cost a dollar to get into the self-serve junkyard, and that you didn’t actually have to BUY anything! You could just go in there for your dollar and take sheit apart, learning how things are put together. He opined that the yard didn’t really care, because they basically bought the cars for their scrap metal value.
This made a lot of sense to me, and I filed it away for future reference.
About a year later I acquired a Suburban that had belonged to a mutual friend, and about a year after that the Suburban developed a growl in the steering that I determined was coming from the tilt steering column. I had no idea how tilt steering columns work, and I didn’t want to experiment with my own as a Guinea pig. So off I went to Pick A Part, our local self-serve wrecking yard.
It didn’t take me long to wreck the first Chevy column I tried to dismantle. The second one I got disassembled, but still damaged a few parts in the process. During that process, the light bulb went off that a puller was needed at the pivot point to remove the main pivots. But I didn’t have a puller.
I theorized that if I put a socket over the pivot, a washer over the socket, and a bolt through the washer and socket that would thread into the pivot, that it would exert the required force like a real puller. Well I tried it on the third column and it worked perfectly! I had in front of me all the parts of an unbroken Chevy tilt steering column, and I studied them for several minutes. Then I went home.
I had my column apart in no time flat, and I could see that one of the support bearings had been installed backwards, its eccentric cage rubbing on the race. I flipped it over and it was better, but not as smooth as the one in the junkyard. And more importantly, they looked to be identical in size. Hmmm.
They had ink stamped my hand at the yard for free, same-day re-entry. So I went back to the yard, walked back to the vehicle I had successfully dismantled with my satchel of hand tools, casually dropped the caged bearing in the bottom of the bag, and walked out again. It fit perfectly in the Suburban, and I never had another issue with that column for the 15 years that I owned it.
Thank you Robert Hooper.
Note: if you enjoyed this, please consider hitting the like button 😊
At local yard (haven't been there in years) for your entry fee anything you could fit in your pockets was free. Wear cargo pants.
Learn how to fix switches, relays, small motors on real items. Then there is always bulbs, knobs, fuses, fasteners and seat belt material.
During Covid the local yards in these parts stopped letting anyone out into the yard. Unfortunately, they still don’t allow anyone now. So rather than going and pulling the parts you need, they tell you a price, and sight unseen you either agree and they pull the part or you walk away. :(
Unfortunately this means that for simple things like inner door panels, they tell you they’re too beat up to sell… and you walk away. Meanwhile the ones in my Toyota car are trashed from years of our protective and territorial dog’s nails wacking at them. Even though the worst set is probably 10 times better than mine, I can’t go find a pair, and they won’t sell me any.
The last time I was in there they had 15 Toyotas just like mine. But most were Taxi cabs and they are too beat up for them to sell for $75/each. Gone are the days of pulling 1/2 decent parts and paying them $10 for parts that would otherwise be crushed with the picked clean carcass of a car.
Now everything is in like new condition and costs 1/2 to 3/4 the price of new parts.
If I want a hydro boost master brakes for my Diesel Ford van it’s $450 for used parts with little to no warranty. It’s almost worth buying new… but then you don’t have all the correct nuts, bolts, and brackets to make it all fit perfectly. So instead I stick with what I have and replace the Vacuum pump every few years. And make the best of what came with it. 🤷‍♂️
A few years back I did replace my ‘97 Ford E350 booster & master with an ‘01 Ford E350 booster & master. After having custom brake lines made the larger bore booster works great. However, scrounging up parts from private individuals is more hit and miss than wreckers of days gone by. And figuring out what parts can be interchanged between different years and models can be tricky.
Figuring out what works and making it work is part of what’s fun about old Landcruisers… and with Mud as a resource… I’m not flying completely blind anymore. Toyota has been great for making parts that interchange well between years and models. Although it has resulted in a bit of a Frankenstein 40.
That said, I feel overall what I have now has the best parts of many years and models of 40s & other Landcruisers. Sorry purists… I’ll not apologize for my 40 having great brakes, steering, and ventilation. :cheers:
I have done this so many times! Even though it's one of the more post-apocalyptic places to hang out, it's still really fun to pull parts and see how stuff works. I haven't been doing this for decades like some, but I've been doing it long enough to see changes in the yard. Times were that I could pull a part I needed for one of my projects, and pull a few others to sell for profit. I could take a $10 part and sell it for $80. Now, the yard wants $40 for the part, and I couldn't get $60 for it if I tried.
Plus the yards have changed, of course. Generally they are full of late-model junk that goes into the yard fairly complete, and leaves for the crusher fairly complete. They're just designed to run until the warranty is up or the lease is over, and then time to trade in for a new one. On the treadmill.
It is gratifying to see the odd pre-2002 Toyota in the yard, a metal shell picked clean of its parts. My wife and I saw this brand new Chevy truck on the road earlier this morning, and it was a total beast - cab as big as a minivan, with a full bed behind it. The hood stood about 6' above the ground. It probably cost north of $80K. And it'll be in that yard in just a few short years. How this is ecologically or economically sound is apparently above my pay grade. /r
We used to ride our bikes to the junkyard near the airport in south Philly and play in the wrecked cars. I remember seeing bits of bone & flesh in the really bad ones. That was chilling for a twelve year old.
Years ago, I worked as a volunteer cadaver dog handler. We'd train on wrecked cars.
Thief! 😄
When I was young, in the service, married with kiddo’s…..and we all were broke, I suspect we all drove the cheapest wreck of a car available. To make it to morning muster…I had to have a transportation that ran…..I remember pushing a broke motorcycle two or three miles to the house, working all weekend to get it running so I could make it to work on Monday. I also remember a time, a weekend before setting off on a 6 month deployment, the wife backing out of the driveway in a Ford PU and when she shifted into drive, sounded like the old AAmco transmission commercial….crunch, pop, bang….myself, and my neighbor (another Navy Chief) pulled the transmission, disassembled it, found the broken bit, reassembled with a weld repaired pin, new clutches and steelies….reinstalled and drank one last beer. She drove me to the pier to wave goodbye in that truck. Necessity is the mother of training, curiosity in how things works isn’t necessarily a driver.
There’s an incredibly rewarding feeling when you’re trying to build something and everything falls into place…
You find that the taper in the pitman arm, that you saved in ‘96, from the September 1969 Bel Air is exactly has exactly the correct taper as a TRE from an ‘80s Toyota pickup someone gave you with some 40 steering parts 15 years prior. When you measure it you find it is 5” longer than the Landcruiser TRE that connects the relay rod to the Bel Crank and its threads match those of the relay rod.
Now the relay rod connects to the Saginaw Scout II box. Now, at least in theory, I should be able to pick up replacement parts from the local auto parts store... even on a Sunday afternoon... and then drive it to work bright and early Monday morning. The only thing I changed was to redrill the taper on the pickup TRE so that I can bolt on an aftermarket 60 series steering stabilizer (after moving the fixed end about 4" toward the passenger side of the front crossmember.
We had no $ when I was a kid in the early 1970's and we had an old Renault R8 sedan for a car. My father found a junked R8 in a local bone yard and as he needed parts he picked them for pennies on the dollar. It was his little honey hole of R8 parts. He picked used brake pads at night so he could get to work in the morning. The yard owner probably took pity on him and was nice enough to not crush it for a few years. I learned a lot watching my dad fix those cars which were our lifeline.
During the cash for clunker days I was broke and I would go there just to pull select desirable parts and sell for a profit mostly on ebay. My favorite was Previa superchargers. They had a cluch on them just like AC so they were sold as "compressors" $25 I'm pretty sure.
I remember buying birfields and telling the cashier they were Volkswagen CVs. $15 each.
Me also. Before all the u-pull-it yards got bought up by Pick-N-Pull, you could get some real deals and flip them. LeBaron turbos when The Fast and Furious came out were gold!
Every yard around me is now a Pick-N-Pull - a publicly traded company. The prices are insane and fluctuate based on how things are selling on sites like eBay. They've gone with the Goodwill model. Sucks.
Prices at all the yards here have skyrocketed. Nothing is affordable, and they won't let you in the yard... much less pull your own parts. Often they want more than 1/2 the price of new for a rusty dirty part and it's often cheaper to buy an aftermarket part with a good warranty than a dirty used part.
