Flywheel cover important to have?
SoCal - westsiiiide
I notice that my rig is missing the flywheel cover. is it important to have this in place? do not know why the last owner removed it, but it is not there.
It keeps trash from getting into your clutch. If you don't ever get off road, you probably can get by without it. If you wheel it, you will likely get lots of road dirt and maybe rocks up in there.
havent had one for 15 plus years no probs. probably wouldnt hurt to have one.
Tends to let added grime get to the throwout bearing so will increase wear. Otherwise not a huge issue. I might suggest keeping an eye on Ebay if you don't have one and bid when one comes up.
Do you need one for a thre speed or four speed? I have a free one for the three speed.
Ed
Had a friend who rapped-up vegitation on his output shaft, causing the throwout bearing to move backwards as if he were stepping on the clutch. Truck obviously would not move as the clutch is now dis-engaged. Took us about 30 minutes to get everything right again.
CruisinGA said:
I drove for a few days after my 420 convo without one- was glad to get it back on.
I do a lot of river crossings, anything to help keep crap and water out of the clutch is a good thing.
If you're crossing water you're not likely to keep it out of the clutch even with the cover on. But ya it's good to use protection. :D
Ed
I have a 1974 4 speed. what do you have? it is something I would like to put on if you havr it?
Ahhhh, mine is for a tree speed, sorry.
Ed
